LCD Display
1 Answer 0 Score |
Why is my laptop not turning on |
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Toshiba Satellite P105-S6024 is a laptop that was released in August of 2006. The P105-S6024 model is a part of a larger P series of Toshiba Satellite laptops that was discontinued in 2016.
The P105-S6024 was sold worldwide, and in the U.S. it was sold for $1,149. This model of Toshiba P series laptop was intended to be affordable when compared to other P series laptops and other competitors to Toshiba during its time.
A common critique of the P105-S6024 was its lower end specifications when compared to others of its series. This model of laptop also had a smaller TrackPad that was uncomfortable for on-the-go use.
Source: CNET Review: Toshiba Satellite P105-S6024
Later models of Toshiba P series Satellite laptops improved the specifications and hardware design.
Identification
The Toshiba Satellite P105-S6024 is a larger laptop with a 17-inch screen size with a grey and silver colored body. It includes a full-size keyboard with a 10-key numpad.
The Toshiba Satellite P105 series can be distinguished from other Toshiba laptops with its audio jacks and volume controls on the front of the laptop's base and its front facing speaker grilles on the bottom of the keyboard housing. There is also a silver emblem found at the top of the keyboard housing that spells out Satellite.
The model and serial number is on the bottom of the laptop. This information is both on a Toshiba marked sticker and etched into the laptop.
The P105-S6024 model in particular had lower specifications compared to others in the P105 series. This is due to the original affordability of the laptop back in August of 2006.
The P105-S6024 model weighs 7.1 lbs. and has dimensions of 15.5" x 10.8'" x 1.41" (WxDxH).
Source: Satellite P105-S6024 Detailed Specs
Technical Specifications
System Configurations:
- Operating System
- Genuine Windows XP Media Center Edition 2005
- Windows Vista Capable
- TOSHIBA Express Media Player
- Processor
- Intel Core Duo Processor T2050. 1.60GHz, 2MB L2, 533MHz FSB
- Mobile Intel 934GM Express Chipset
- Intel PRO/Wireless 3945ABG
- Memory
- 1024MB DDR2 SDRAM
- Toshiba Satellite P105-S6024 memory can be upgraded.
- Hard Disk Drive
- 100GB SATA hard drive. 5,400 RPM, 9.5mm height.
- Display
- 17 inch widescreen. LCD display at 1440x900 native resolution.
- Graphics
- Intel Graphics Media Accelerator 950. 32MB-128MB of dynamically allocated shared graphics memory.
- Speakers
- Built in harman/kardon stereo speakers.
- SRS TruSurround XT and SRS WOW stereo enhancements
- 16-bit stereo software sound with Intel High Definition Audio.
- Input Devices
- 103 key US keyboard with 10-Key
- Hot Key Functions (Fn)
- TouchPad pointing device
- Battery:
- 6-cell (4000mAh) rechargeable, removable Lithium Ion (Li-Ion) battery pack.
- Battery life is expected to be 2 hours and 17 minuets.
- Recharge time is expected to be an approximate 4.0 to 12.0 hours.
Hardware
- Dimensions
- 15.5" x 10.8'" x 1.41" (WxDxH)
- Weight
- 7.1 lbs.
- Power Supply
- Dimensions: 5.0" x 2.0" x 1.2" (WxDxH)
- Specifications: 75W AC Adapter. 100-240V/50-60Hz frequency (Universal) Input.
- Weight: 0.80 lbs.
BIOS
ACPI v1.0, PNP v1.0a VESA v2.0, DPMS v1.0, DDC v1.0, SM BIOS v2.4, PCI BIOS v2.2 support.
Source: Toshiba Satellite P105-S6204 Detailed Specs
Additional Information
Toshiba Satellite P105-S6024 Official Support Page
Toshiba Satellite P105-S6024 User Manual
Toshiba Satellite P105-S6024 Detailed Specs
Toshiba Official How-To Videos
