Ask a Question
There are no questions. Be the first to ask a question!
Background:
The Wyze WVCR200s Robot Vacuum is an autonomous robot that eliminates the hassle of vacuuming your house. This robot vacuum has a technologically advanced mapping system for the most efficient planning and route to ensure a satisfactory cleaning.
The Wyze Vacuum Robot has the ability for high precision mapping due to its 7 sensor groups and over 2,000 distance points. In the app, you are able to customize your robots map, select particular rooms that you want cleaned, schedule regular cleaning times, and adjust suction/noise levels.
This vacuum was designed for usage on many different surfaces found in homes such as hardwood and carpets. The vacuum has the ability to connect to Alexa, so if necessary, it can be hands free.
Identification:
The Wyze WVCR200s has a compact circular design similar to most robot vacuums. Extending from the top half the vacuum is the LIDAR sensor which can be seen as a circular scanner like device with the Wyze logo on top of it. Underneath the vacuum on the bottom center between the two wheels there should be an information panel containing data about the device including the model number.
Technical Specifications:
  • Color: Black
  • Weight: 7.2 pounds
  • Phone Compatibility:
    • Android – 5.0+
    • IOS – 9.0+
  • Vacuum Dimensions:
    • Length: 13.8 inches
    • Width: 13.8 inches
    • Height: 3.7 inches
  • Charging Station Dimensions:
    • Length: 6.06 inches
    • Width: 2.95 inches
    • Height: 3.90 inches
  • Languages: English
  • Vacuum Power Source:
    • Rated voltage: 14.8 volts
    • Rated power: 33W
  • Charging Station Power:
    • Rated power: 24W
    • Rated input: 20V ⎓ 1.2A
    • Rated output: 20V ⎓ 1.2A
    • Rated frequency: 50/60Hz
  • Communication: 2.4GHz Wifi
  • Recommended Operating Temperature: 32F - 13-F (0C - 55C)
  • Weather Resistance: Indoor use only
  • Warranty: 1-year
Additional Information:
Manufacturers Website
Wyze WVCR200s on Amazon
Review on PCMagazine.com
Brandon Amado
411 Reputation
2 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 33
All Time: 1,341
