Accessory Antenna Board
No Answers 0 Score |
Power button or pair button board flat cable port replacement |
1 Answer 0 Score |
My Xbox Ethernet got hit with lightning |
Documents
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
1882 2024 Refresh 1TB 14 digit serial number
Background
The original Xbox Series X was released in late 2020. Four years later, in late 2024, Microsoft updated their Xbox Series X|S line with a "mid-cycle refresh," including a 1 TB Series S (previously only available with 512 GB), a special edition "Galaxy Black" 2 TB Series X with a speckled paint job, and this console, the Xbox Series X 1 TB Digital Edition, a regular Series X, now in Robot White, and now without a disc drive.
The Xbox Series X Digital Edition, like the original Series X, targets true 4K gaming at 120 fps. It features an identical system-on-chip (SoC) with AMD’s Zen 2 CPU and RDNA 2 GPU architectures.
The Xbox Series X Digital Edition is priced at $449.99 USD and, at launch, is only available in Robot White.
Identification
The Series X Digital Edition is a white rectangular box, standing vertically. It's quite a bit larger than the One X and One S and is designed to resemble a small PC tower. The ports on the back come with some tactile identification in the form of tiny raised dots. There's a Master Chief logo on the massive fan, which can be seen by removing the back panel.
The model number and other information can be found on the back of the console.
Specifications
CPU: AMD custom 8-core Zen 2 CPU @ 3.8 GHz (3.6 GHz w/SMT)
GPU: AMD custom RDNA 2 GPU @ 1.825 GHz w/52 compute units
Memory: 16 GB GDDR6
Memory Bus: 320-bit
Memory Bandwidth: 10 GB @ 560 GB/s, 6 GB @ 336 GB/s
Storage: 1 TB custom NVME SSD
Expandable Storage:
- Support for Xbox Series X|S 1 TB expansion cards
- Support for USB 3.1 external drives
AV Output:
- 1x HDMI 2.1 (support for 8K @ 60 fps, 4K @ 120 fps)
- Up to 8K HDR support
- AMD FreeSync
I/O Output: 3x USB 3.1 Gen 1
Sound:
- Dolby Digital 5.1, DTS 5.1
- Dolby TrueHD with Atmos
- Up to 7.1 L-PCM
Communication:
- 802.3 10/100/1000 ethernet
- 802.11ac dual-band Wi-Fi
Optical Drive: None
Dimensions: 15.1 x 15.1 x 30.1 cm (5.94 x 5.94 x 11.85 in)
Weight: 4.4 kg (9.8 lbs)
