5 Answers 3 Score |
Battery replacement on Bip |
3 Answers 3 Score |
battery not holding charge |
3 Answers 4 Score |
Screen fell off - what can I use to reattach? |
2 Answers 2 Score |
Screen spoiled... After swimming.. can you fix it |
Background and Identification
The Xiaomi Amazfit Bip is marketed as a smartwatch for sports and was released in 2017. The watch launched in the U.S. in early 2018 and came to the U.K. several months later. Amazfit is a brand within Huami, which is Xiaomi’s wearables supplier. It was released in white, red, grey, and black bodies. Additional white, black, dark blue, and grey straps can replace the original watch band. The Amazfit Bip has a polycarbonate body and a 1.28-inch screen.
The Amazfit Bip has IP68 dust-resistance and water-resistance in up to 1.5 meters of freshwater for up to 30 minutes. It has a color LCD display with a resolution of 176 by 176 pixels. It also has a reflective panel that allows the user to see the time while the watch is on standby. The watch features heart rate, accelerometer, barometer sensors as well as a GPS + GLONASS module. The 4.0 version includes Bluetooth capabilities.
The Amazfit Bip includes 1 MB of RAM memory and 4 MB of internal storage. It also contains a 190 mAh battery that is advertised to last 45 days of use at a 10 percent brightness setting.
A TechRadar review found that the Amazfit Bip has excellent battery life but found that the watch’s auto-pause feature does not work and the user-interface is subpar.
Technical Specifications
Models: A1608, A1608B
Weight: Body 18g, with Strap 32g
Screen type: Transflective color display
Screen material: 2.5D Corning gorilla glass 3rd generation + AF coating
Screen Size: 1.28 inches
Waterproof and Dustproof: IP68 Rating
Strap: Length 11 + 8.5cm / width: 20mm
Processor: Mediatek
Sensors: PPG heart rate sensor, triaxial acceleration sensor, geomagnetic sensor, barometric pressure sensor
GPS: GPS + GLONASS dual-mode positioning
Connection: Bluetooth 4.0 BLE
Battery: 190mAh lithium polymer
Charging time: 2.5 hours
Battery Life: 45 Days (time display, motion monitoring, sleep monitoring) – GPS continuous track record: 22 hours (time display, motion monitoring, sleep monitoring) GPS continuous use: 22 hours
Body material: Polycarbonate
Compatibility: Android 4.4, iOS 8 and above
