Display
20 Answers 13 Score |
Horizontal lines over iMac 24 screen |
3 Answers 2 Score |
Is it possible to remove the stand? |
1 Answer 0 Score |
Can I upgrade from 8 GB to 16 GB? |
1 Answer 2 Score |
How to fix my slightly cracked screen? |
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
A2438 EMC 3663 M1 (8-Core/8-Core GPU/4 Ports) iMac21,1, A2439 EMC 3664 M1 (8-Core/7-Core GPU/2 Ports) iMac21,2
Background
Announced April 20th, 2021 and released May 21st, 2021, Apple’s 24” iMac is completely redesigned. With white bezels, new colors, and a thin 11.5 mm profile, the 2021 24” iMac is the first iMac with Apple’s own silicon.
Starting at $1299, it’s available in either blue, green, pink, or silver. Yellow, orange, and purple become available on models starting at $1499.
The 24” iMac ships with a Magic Keyboard, a Magic Mouse, and a braided magnetic charging connector, all color-matched.
Identification
Identify your iMac by the model number or EMC number printed on the foot (the bottom of the stand).
You can also find the model number through macOS by choosing About This Mac from the Apple menu in the upper-left corner of the screen.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your iMac model.
Technical Specifications
Display: 23.5” 4.5K Retina display with True Tone; 4480 x 2520 pixels (16:9 aspect ratio, 218 ppi); P3 wide color gamut; 500 nits
Processor: Apple M1 3.2 GHz 8-core CPU, 16-core Neural Engine
Graphics: Apple M1 integrated 7-core GPU, configurable to 8 cores
Storage: 256 GB SSD, configurable to 512 GB, 1 TB, or 2 TB
Memory: 8 GB of unified memory, configurable to 16 GB
Camera: 1080p FaceTime HD with M1 ISP
Wireless: 802.11ax Wi-Fi 6 and Bluetooth 5.0
Dimensions
- Height: 18.1 in (46.1 cm)
- Width: 21.5 in (54.7 cm)
- Depth: 5.8 in (14.7 cm)
- Weight: 9.83-9.88 lbs (4.46-4.48 kg)
Ports
- 2x Thunderbolt / USB 4 ports (Thunderbolt 3, USB-C 3.1 Gen 2)
- 1x 3.5 mm headphone jack
- Configurable with 2x USB 3 ports (USB-C)
- Configurable with 1x Gigabit Ethernet port
