No Answers 0 Score |
Why it won’t charge |
Background Information
Announced the morning of May 7th, 2024, Apple's 5th generation 11-inch iPad Pro and 7th generation 13-inch iPad Pro have been refreshed for the first time since 2018. Available in both the previously-available 11-inch and new-for-2024 13-inch sizes, they feature new Ultra Retina XDR displays with "tandem OLED" technology, debut with the new M4 SoC, and support for the new Apple Pencil Pro. The front-facing camera has been moved to the landscape edge and the base storage has been increased from 128 to 256 GB.
The 5th generation 11-inch iPad Pro and new 13-inch iPad Pro are Apple’s first devices to use the M4 chip.
The 5th generation 11-inch iPad Pro starts at $999 and is available in either Silver or Space Black.
Identification
The 5th generation 11" iPad Pro notably shrunk in size for 2024 and is thinner than the outgoing model. The aluminum back case extends over the camera bump and the charging port is USB-C.
iPad model numbers are etched into the back case. Look here to follow Apple's instructions to identify your iPad model.
Technical Specifications
Display:
- 11-inch, 2420 x 1668 (264 ppi) Ultra Retina XDR Tandem OLED display
- 10–240 Hz ProMotion dynamic refresh rate
- P3 color gamut, 2,000,000:1 contrast ratio
- 1000 nits max SDR brightness, 1600 nits peak HDR brightness
Chip:
- M4 SoC, 9-core CPU, 10-core GPU, 16-core Neural Engine
- Configurable to 10-core CPU
Memory:
- 8 GB, configurable to 16 GB (both 120 GB/s bandwidth)
Storage:
- 256 GB, configurable to 512 GB, 1 TB, and 2 TB
Battery:
- 31.29 Wh Li-Po
Cameras:
- Rear-facing 12 MP Wide, ƒ/1.8 aperture, 5-element lens
- 4K video recording up to 60 fps
- Slo-mo video recording up to 1080p 240 fps
- Adaptive True Tone flash
- Front-facing 12 MP TrueDepth Ultra Wide, ƒ/2.4 aperture
Sensors:
- Face ID
- LiDAR Scanner
Connectivity:
- Thunderbolt 4 / USB 4 USB-C port (up to 40 GB/s)
- Smart Connector (for keyboards and accessories)
- Magnetic connector (for Apple Pencil)
- Wi-Fi 6E (802.11ax) with 2x2 MIMO
- Bluetooth 5.3
- Cellular models: 5G sub-6 GHz with 4x4 MIMO, eSIM
Dimensions and Weight:
- 9.83 x 6.99 x 0.21 inches (249.7 x 177.5 x 5.3 mm)
- 0.98 lbs (444-446 g)
