Battery
No Answers 0 Score |
How to link up with iPhone 8 |
When attempting to connect to my network,it displays a Roomba network |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The iRobot Roomba 694 was first released in 2020. This vacuum is designed to effortlessly clean dirt, dust, and debris in the home. The 694 model is a part of the 600 series from iRobot, and it is considered part of the evolution of vacuum technology. This model has adaptive navigation, it includes sensors to avoid most, if not all, collisions with any furniture, walls, or appliances. The model also has voice recognizing technology such as Google Assistant and Alexa. The Dirt Detectâ„¢ sensors will allow the Roomba to detect the areas of your home that gather more dirt and debris, and pass by those more often.
This model is said to remove about 97% of dirt and debris from all areas of any floor type. This model is also extremely cost effective, using simpler technology for the same quality of use, while only costing about $274 USD. The Roomba 694 is said to have excellent battery life and thorough cleaning capabilities, along with a modern look, making it a great option for consumers.
Identification
The 694 model has an updated faceplate, as well as controls. These updates help the Roomba 694 stand out against the 675 model, its predecessor, because it creates a much more modern look.
References:
Modern Castle: iRobot Roomba 694 Review
Specifications
- Roomba Dimensions: 13.4 x 13.4 x 3.5in.
- Box Dimensions: 15.47 x 17.47 x 12.7in.
- Weight: 6.77 lbs.
- Battery: 1,800 mAh Lithium-Ion
- Filter: AeroVac
- Floor Type: All Indoor Flooring
- Dust Bin Capacity: 300 mL
