Introduction
The screen is one of the most important parts of the device, and breaking it may mean the end of its use. Due to the device's age, finding a new screen may be difficult, but if found, replacing it for the old one is straightforward.
Turn the device over so it is face down and remove the stylus, and battery cover.
Using a Philips #0 or #00 screwdriver, locate and unscrew the four screws holding the back cover on the device.
Tool used on this step:Tweezers$4.99
Locate the brown serial connector on the left side of the device. Using the flat head screw driver bit push the little tabs (one on each side) out towards you as pictured.
They should extend about 1/16 of an inch (1.5 mm).
Now take the tweezers and gently pry out the serial tab as shown .
Use the tweezers, or your fingers, to remove the physical button strip.
Use the ipod opening tool to pry the cover from the internal plastic frame; the internal frame and screen will come off at the same time.
Place the front cover aside.
