1922 GE AOU Fan Power cord Replacement
  1. 1922 GE AOU Fan Power cord Replacement, Power cord: step 1, image 1 of 2 1922 GE AOU Fan Power cord Replacement, Power cord: step 1, image 2 of 2
    • Tip the fan to its side and remove the three size 8 screws using a 9/32 flat-head screwdriver.
    • The screws may be brittle from age, so be careful.
    • Take the bottom plate off the fan and set it aside.
  2. 1922 GE AOU Fan Power cord Replacement: step 2, image 1 of 1
    • Remove the three number 8 screws that hold the switch in place.
  3. 1922 GE AOU Fan Power cord Replacement: step 3, image 1 of 1
    • Remove the switch, carefully sliding the speed lever out of its slot.
    • Don't remove the switch too quickly or you can damage the head-wire.
  4. 1922 GE AOU Fan Power cord Replacement: step 4, image 1 of 1
    • Once the switch is free, unscrew the two knurled nuts holding the wires in place.
  5. 1922 GE AOU Fan Power cord Replacement: step 5, image 1 of 1
    • Turn the switch over and unscrew the nut securing the wire with the 5/16 crescent wrench.
  6. 1922 GE AOU Fan Power cord Replacement: step 6, image 1 of 1
    • Remove the switch and set it aside, then pull the wire through the grommet.
Elias Dorna
125 Reputation
1 Guide authored
Texas Tech, Team 3-5, Rauch SU 2016 Member of Texas Tech, Team 3-5, Rauch SU 2016
TTU-RAUCH-SU16S3G5
2 Members
1 Guide authored
One Comment
Westinghouse table fan needs new cord (just bought). 18 gauge cord? Where to buy?
carol w - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 2,793
