1988-1997 Ford Thunderbird Speakers Replacement
  1. 1988-1997 Ford Thunderbird Speakers Replacement, Speakers: step 1, image 1 of 2 1988-1997 Ford Thunderbird Speakers Replacement, Speakers: step 1, image 2 of 2
    • Use a plastic pry tool (or screwdriver but be careful) to pop the black panel off of the door.
  2. 1988-1997 Ford Thunderbird Speakers Replacement: step 2, image 1 of 2 1988-1997 Ford Thunderbird Speakers Replacement: step 2, image 2 of 2
    • Once the black panel has been removed, take out the power side mirror plug (if you have one)
  3. 1988-1997 Ford Thunderbird Speakers Replacement: step 3, image 1 of 1
    • Begin romving the power windows connector by removing the screws, then prying off the plastic connectors
  4. 1988-1997 Ford Thunderbird Speakers Replacement: step 4, image 1 of 2 1988-1997 Ford Thunderbird Speakers Replacement: step 4, image 2 of 2
    • Remove the bolt holding on the plastic to the door.
  5. 1988-1997 Ford Thunderbird Speakers Replacement: step 5, image 1 of 2 1988-1997 Ford Thunderbird Speakers Replacement: step 5, image 2 of 2
    • Pry the plastic off of the light enclosure on the bottom of the door. Once you remove it, take the screw out. This is the only other screw holding the door on.
  6. 1988-1997 Ford Thunderbird Speakers Replacement: step 6, image 1 of 1
    • Now your door should look like this! (With some Ford factory duct tape)
  7. 1988-1997 Ford Thunderbird Speakers Replacement: step 7, image 1 of 1
    • Once you've removed the speaker off of the door by removing the bolts unplug it. This is the connector
  8. 1988-1997 Ford Thunderbird Speakers Replacement: step 8, image 1 of 1
    • Once you solder the wires (or crimp them) replace the new speaker on to the door.
  9. 1988-1997 Ford Thunderbird Speakers Replacement: step 9, image 1 of 3 1988-1997 Ford Thunderbird Speakers Replacement: step 9, image 2 of 3 1988-1997 Ford Thunderbird Speakers Replacement: step 9, image 3 of 3
    • Moving to the back, use your screw driver or pry tool on the BOTTOM of the panel.
    • Pry it outward, then pull it out.
  10. 1988-1997 Ford Thunderbird Speakers Replacement: step 10, image 1 of 2 1988-1997 Ford Thunderbird Speakers Replacement: step 10, image 2 of 2
    • Remove the speaker like the driver's side (as show earlier)
    • Unplug the speaker, solder the wires, put the bolts back on afterwards
  11. 1988-1997 Ford Thunderbird Speakers Replacement: step 11, image 1 of 1
    • Here's the passenger side door panel taken out. remove the screws and pry out like the driver's side
  12. 1988-1997 Ford Thunderbird Speakers Replacement: step 12, image 1 of 2 1988-1997 Ford Thunderbird Speakers Replacement: step 12, image 2 of 2
    • Follow the same steps from the driver's side for the passenger's side, replace all the plastic, and enjoy!
3 other people completed this guide.
Kyle
200 Reputation
1 Guide authored
One Comment
What's the positive wire for the speakers
brucebanaszak - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 5,847
