1992-1996 Ford Bronco Spark Plug Replacement
  1. 1992-1996 Ford Bronco Spark Plug Replacement, Open the hood: step 1, image 1 of 3 1992-1996 Ford Bronco Spark Plug Replacement, Open the hood: step 1, image 2 of 3 1992-1996 Ford Bronco Spark Plug Replacement, Open the hood: step 1, image 3 of 3
    • First, go inside the driver's door and down to the left, as shown in the picture, and pull the latch away from the pedals.
    • Then go around to the front of the vehicle and locate the latch in the grill.
    • While slightly pushing down on the hood push the latch to the left and then push the hood up.
  2. 1992-1996 Ford Bronco Spark Plug Replacement, Remove the air intake hose: step 2, image 1 of 3 1992-1996 Ford Bronco Spark Plug Replacement, Remove the air intake hose: step 2, image 2 of 3 1992-1996 Ford Bronco Spark Plug Replacement, Remove the air intake hose: step 2, image 3 of 3
    • Locate the fasteners that hold the intake hose in place.
    • Using a 5/16" wrench remove all 4 bolts on the fasteners.
    • Grab the hoses at the fasteners and pull away from and off of their respective slots.
  3. 1992-1996 Ford Bronco Spark Plug Replacement, Locate and uncover the spark plug: step 3, image 1 of 3 1992-1996 Ford Bronco Spark Plug Replacement, Locate and uncover the spark plug: step 3, image 2 of 3 1992-1996 Ford Bronco Spark Plug Replacement, Locate and uncover the spark plug: step 3, image 3 of 3
    • Looking at the right and left side of the engine you should see the 4 spark plugs per side in these locations.
    • They will be covered as you see the 2nd, 3rd, and 4th are in the second image.
    • *We recommend uncovering and changing one at a time to ensure each wire goes back on the correct spark plug.*
    • To uncover the spark plugs grab the wire at the end covering the spark plug and pull away from the spark plug.
  4. 1992-1996 Ford Bronco Spark Plug Replacement, Remove the spark plug: step 4, image 1 of 1
    • Using a 5/8" wrench loosen and remove the spark plug.
  5. 1992-1996 Ford Bronco Spark Plug Replacement, Insert the new spark plug: step 5, image 1 of 1
    • Insert the new spark plug in the same spot.
    • Start by hand tightening. *A good idea is to lightly push in and turn the spark plug to the left or counterclockwise until it drops into the grooves and then hand tighten to the right or clockwise to prevent cross-threading.*
    • You can then tighten a bit more with the 5/16" wrench.
    • Finally, reattach the spark plug wire by slipping it over the new spark plug and pushing it on.
  6. 1992-1996 Ford Bronco Spark Plug Replacement, Repeat: step 6, image 1 of 2 1992-1996 Ford Bronco Spark Plug Replacement, Repeat: step 6, image 2 of 2
    • Repeat steps 3-5 a total of 7 more times for the remaining spark plugs.
  7. 1992-1996 Ford Bronco Spark Plug Replacement, Reattach the air intake hose: step 7, image 1 of 2 1992-1996 Ford Bronco Spark Plug Replacement, Reattach the air intake hose: step 7, image 2 of 2
    • Put the air intake hose back with each end of the hose over its 2 respective slots.
    • Put the 4 bolts back onto the fasteners and tighten the hose back in its place.
    • Close the hood and the replacement is finished.
Finish Line
Jackson Rezach
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 312
