1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement
Video Overview
  1. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement, 3.4L Timing Belt/ Water Pump: step 1, image 1 of 1
  2. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 2, image 1 of 1
  3. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 3, image 1 of 1
  4. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 4, image 1 of 3 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 4, image 2 of 3 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 4, image 3 of 3
  5. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 5, image 1 of 1
    • Loosen up the idler pulley by getting underneath the car and removing the 12mm bolt at the bottom of the idler pulley .
  6. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 6, image 1 of 1
  7. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 7, image 1 of 1
  8. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 8, image 1 of 1
  9. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 9, image 1 of 1
  10. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 10, image 1 of 1
    • Remove the nut that holds the pulley in place, which should be torqued down to 250 lbs .
  11. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 11, image 1 of 1
    • Using a 19mm wrench and a pipe, remove the nut and then remove the pulley .
  12. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 12, image 1 of 1
  13. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 13, image 1 of 1
  14. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 14, image 1 of 1
  15. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 15, image 1 of 1
  16. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 16, image 1 of 1
    • Line up the notches on the camshafts to set the timing before removing the belt .
  17. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 17, image 1 of 1
  18. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 18, image 1 of 1
    • Line up the camshafts by rotating the big pulley until the notches line up .
  19. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 19, image 1 of 1
  20. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 20, image 1 of 1
  21. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: step 21, image 1 of 1
Additional Information
- When lining up the camshafts, make sure to align the notches with the backplate, as well as the small arrow and dot on the bottom
- It is important to get all the old gasket off to prevent leaks.
5 other people completed this guide.
eCuration
378,307 Reputation
236 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,902 Guides authored
One Comment
Thank you so much for the video! As for ordering the parts for this repair i will go ahead and save a lot of trouble for those of you who may not already know when asked about weather you need the water pump that comes WITH ot WITHOUT the ENGINE oil cooler stem, I own a 1999 Toyota Tacoma Four-Wheel Drive V6 3.4L 5-Speed Manual Transmission
NikkiAutumn - Reply
Past 24 Hours: 7
Past 7 Days: 54
Past 30 Days: 316
All Time: 61,894
