1995-2002 Toyota 4Runner Front Brake Pad Replacement
Video Overview
  1. 1995-2002 Toyota 4Runner Front Brake Pad Replacement, Front Brake Pad: step 1, image 1 of 1
    • Loosen all six lug nuts on the passenger side wheel before jacking up the vehicle .
  2. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 2, image 1 of 1
    • Use a floor jack to lift up the passenger side of the vehicle at the jacking point recommended by the manufacturer, right underneath the front suspension .
  3. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 3, image 1 of 1
    • Place jack stands next to the jacking point and another one as a safeguard back on the frame .
  4. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 4, image 1 of 1
  5. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 5, image 1 of 3 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 5, image 2 of 3 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 5, image 3 of 3
    • Spray Liquid Wrench or WD-40 on the two 17mm bolts holding the brake caliper in place
    • These bolts are located behind the caliper .
  6. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 6, image 1 of 3 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 6, image 2 of 3 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 6, image 3 of 3
    • Use a torque wrench to break the 17mm bolts free, then switch to a socket wrench to remove them completely .
  7. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 7, image 1 of 1
    • Pop the clip that holds the hard brake line to the soft brake line out using a hammer and flathead screwdriver .
  8. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 8, image 1 of 1
    • Use bailing wire to hang the brake caliper out of the way, ensuring it is not hanging on the brake line .
  9. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 9, image 1 of 1
    • Remove the old rotor
    • If it is stuck, use a dead blow hammer to knock it loose .
  10. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 10, image 1 of 1
    • Install the new rotor and secure it in place using two lug nuts to align it correctly .
  11. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 11, image 1 of 3 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 11, image 2 of 3 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 11, image 3 of 3
    • Remove the pins holding the old brake pads in place and take out the old pads .
  12. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 12, image 1 of 1
  13. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 13, image 1 of 1
    • Install the new brake pads and grease the new pins before sliding them into place .
  14. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 15, image 1 of 1
  15. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 16, image 1 of 2 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 16, image 2 of 2
    • Remove the two lug nuts used to align the rotor and put the wheel back on .
  16. 1995-2002 Toyota 4Runner Front Brake Pad Replacement: step 17, image 1 of 1
    • Once the vehicle is on the ground, further tighten the lug nuts to ensure they are secure .
eCuration
378,307 Reputation
236 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,902 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 30
All Time: 4,514
