1996-2000 Honda Civic Spark Plug Replacement
Video Instructions
eCuration
446,646 Reputation
239 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
One Comment
Replacement sparkplugs should always be checked for the right gap. New sparkplugs come with new washers that need to be torqued down to seat the washers, undone, then tightened down again to the required torqued setting. This is important as they can come loose. Also, Its a good idea when you remove the plug wires but before you remove the plugs you should blow down the spark plug tubes to insure there is no dirt or grit that will fall into the cylinders when you remove the plugs. This is why its a good idea to do one sparkplug at a time.
binnaburramick - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 10,925
