1998-2012 Renault Clio II Battery Replacement
  1. 1998-2012 Renault Clio II Battery Replacement, Battery: step 1, image 1 of 1
    • Stop the car engine.
    • Indentify the car battery.
  2. 1998-2012 Renault Clio II Battery Replacement: step 2, image 1 of 1
    • Identify the screw on the right side of the battery which maintains the battery.
  3. 1998-2012 Renault Clio II Battery Replacement: step 3, image 1 of 1
    • WIth the 8mm box end wrench, remove the black (ground) cable.
  4. 1998-2012 Renault Clio II Battery Replacement: step 4, image 1 of 1
    • WIth the 13mm wrench, remove the red cable.
  5. 1998-2012 Renault Clio II Battery Replacement: step 5, image 1 of 1
    • Unscrew the bottom screw identify in step 2 with the 13mm socket wrench.
    • Remove the old battery.
  6. 1998-2012 Renault Clio II Battery Replacement: step 6, image 1 of 1
    • Insert your new battery and lock the it with the screw.
    • Grease the battery contacts.
  7. 1998-2012 Renault Clio II Battery Replacement: step 7, image 1 of 1
    • Put back the red cable and then the black one.
    • Start your car.
Finish Line
20 other people completed this guide.
sissssou
1,485 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 14
Past 7 Days: 82
Past 30 Days: 420
All Time: 57,810
