1998-2002 Honda Accord Tail Light Bulbs Replacement
  1. 1998-2002 Honda Accord Tail Light Bulbs Replacement, Tail Light Bulb Assemblies: step 1, image 1 of 2 1998-2002 Honda Accord Tail Light Bulbs Replacement, Tail Light Bulb Assemblies: step 1, image 2 of 2
    • Open the trunk using your key in the trunk key slot or by using the lever under the driver's console.
  2. 1998-2002 Honda Accord Tail Light Bulbs Replacement, Panel Tail Lights: step 2, image 1 of 3 1998-2002 Honda Accord Tail Light Bulbs Replacement, Panel Tail Lights: step 2, image 2 of 3 1998-2002 Honda Accord Tail Light Bulbs Replacement, Panel Tail Lights: step 2, image 3 of 3
    • Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver.
    • Carefully peel back the trunk liner from around the edge of trunk opening by the light.
    • Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
  3. 1998-2002 Honda Accord Tail Light Bulbs Replacement: step 3, image 1 of 3 1998-2002 Honda Accord Tail Light Bulbs Replacement: step 3, image 2 of 3 1998-2002 Honda Accord Tail Light Bulbs Replacement: step 3, image 3 of 3
    • Grab a light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  4. 1998-2002 Honda Accord Tail Light Bulbs Replacement, Trunk Lid Tail Lights: step 4, image 1 of 3 1998-2002 Honda Accord Tail Light Bulbs Replacement, Trunk Lid Tail Lights: step 4, image 2 of 3 1998-2002 Honda Accord Tail Light Bulbs Replacement, Trunk Lid Tail Lights: step 4, image 3 of 3
    • Locate the light bulb sockets in the trunk lid, located on the back side of the trunk tail lights.
    • Turn the light bulb sockets counterclockwise and remove them from their holes.
  5. 1998-2002 Honda Accord Tail Light Bulbs Replacement, Tail Light Bulbs: step 5, image 1 of 2 1998-2002 Honda Accord Tail Light Bulbs Replacement, Tail Light Bulbs: step 5, image 2 of 2
    • Remove the light bulbs from their sockets by gently pulling them away from the connectors.
12 other people completed this guide.
4 Comments
Mine is a 2002 honda accord EX doest have that kind of fastener on the trunk's carpet... I don't know how to remove those!
Help!
JoeKehr13 - Reply
2001 Honda Accord Coupe - my stero turns on but has no sound, and the brake lamp indicator light came on and my headlights don't work now (running lights, yes). Could these all be connected to a fuse possibly? Help, I'm stuck in a parking lot!
Lindalace - Reply
Try your high beams, they should still work. And if you just replaced a break/tail bulb, then one of the skinny metal contacts inside the plastic sockets has bent down into the socket, causing the bad ground issue. Or your stereo illumination dimmer wire is exposed and shorting out.
Possibly the wrong bulb in one of the sockets as well.
Those are all I can think of right now.
Jax Kadar -
But what size of bulb should I get
Tommy Anguiano - Reply
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 69
All Time: 81,350
