1999-2011 Ford Ranger Tail Light Bulb Replacement
  1. 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: step 1, image 1 of 3 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: step 1, image 2 of 3 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: step 1, image 3 of 3
    • Pull the tailgate latch and lower the tailgate down so that it is open.
  2. 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 2, image 1 of 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 2, image 2 of 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 2, image 3 of 3
    • Remove the two 19mm Phillips #1 screws on the taillight housing that face the inside of the bed.
    • Remove the two 38mm Phillips #1 screws on the taillight housing that face the outside of the truck.
  3. 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 3, image 1 of 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 3, image 2 of 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 3, image 3 of 3
    • Pull the taillight housing down from the truck so that the wires and plugs are exposed.
  4. 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 4, image 1 of 1
    • Remove any dirt or dust around the taillight plug so that nothing falls into the lens.
  5. 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 5, image 1 of 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 5, image 2 of 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 5, image 3 of 3
    • Loosen and remove the taillight plug so that the bulb is exposed.
  6. 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 6, image 1 of 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 6, image 2 of 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: step 6, image 3 of 3
    • Remove the old or damaged bulb.
    • Insert the new bulb into the exposed plug and then insert the plug back into the taillight housing and tighten.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 105
All Time: 6,981
