1999-2007 Chevy Silverado Center Console Lid Replacement
  1. 1999-2007 Chevy Silverado Center Console Lid Replacement, Center Console Lid: step 1, image 1 of 3 1999-2007 Chevy Silverado Center Console Lid Replacement, Center Console Lid: step 1, image 2 of 3 1999-2007 Chevy Silverado Center Console Lid Replacement, Center Console Lid: step 1, image 3 of 3
    • Open the lid and remove the plastic cover by pulling it from the part sticking out on the bottom.
    • Removing the plastic cover may require some force.
  2. 1999-2007 Chevy Silverado Center Console Lid Replacement: step 2, image 1 of 3 1999-2007 Chevy Silverado Center Console Lid Replacement: step 2, image 2 of 3 1999-2007 Chevy Silverado Center Console Lid Replacement: step 2, image 3 of 3
    • A metal rod is found holding the center console and lid together.
    • Remove the metal rod using a screwdriver when pushing it out from the right side.
    • When pushing the metal rod out through the springs, you can go over to the other side and start pulling it out with a vise grip, then with your hand when it gets loosened.
  3. 1999-2007 Chevy Silverado Center Console Lid Replacement: step 3, image 1 of 2 1999-2007 Chevy Silverado Center Console Lid Replacement: step 3, image 2 of 2
    • The springs should now be loose enough to remove them from the holes that keep them in place along with the bracket.
    • Remove the old lid entirely after the bracket and springs are off.
  4. 1999-2007 Chevy Silverado Center Console Lid Replacement: step 4, image 1 of 3 1999-2007 Chevy Silverado Center Console Lid Replacement: step 4, image 2 of 3 1999-2007 Chevy Silverado Center Console Lid Replacement: step 4, image 3 of 3
    • Place the new lid in the place where the old lid was.
    • Attach the new bracket to where the marked boxes are.
  5. 1999-2007 Chevy Silverado Center Console Lid Replacement: step 5, image 1 of 3 1999-2007 Chevy Silverado Center Console Lid Replacement: step 5, image 2 of 3 1999-2007 Chevy Silverado Center Console Lid Replacement: step 5, image 3 of 3
    • The marked boxes identify the tiny holes where the straight part of the springs will go into.
    • Insert the springs with the curvy part facing up and put it through the bracket hole at an angle so it can go through the other hole above it.
  6. 1999-2007 Chevy Silverado Center Console Lid Replacement: step 6, image 1 of 2 1999-2007 Chevy Silverado Center Console Lid Replacement: step 6, image 2 of 2
    • Once the springs and hinges are aligned, put the new metal rod in through them by tapping it in all the way with a vise grip on the left side.
    • Any tool can be used to tap or push the metal rod in.
  7. 1999-2007 Chevy Silverado Center Console Lid Replacement: step 7, image 1 of 3 1999-2007 Chevy Silverado Center Console Lid Replacement: step 7, image 2 of 3 1999-2007 Chevy Silverado Center Console Lid Replacement: step 7, image 3 of 3
    • The marked squares indicates the clamps the new plastic cover must click on.
    • Press all around the sides to ensure all the clamps have made a clicking sound so the plastic cover will not loosen and fall apart later on.
Robert Gonzalez
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 66
All Time: 515
