1999 - 2003 Acura TL Ignition Coil Replacement
  1. 1999 - 2003 Acura TL Ignition Coil Replacement, Ignition Coil: step 1, image 1 of 2 1999 - 2003 Acura TL Ignition Coil Replacement, Ignition Coil: step 1, image 2 of 2
    • Open the driver side door of car.
  2. 1999 - 2003 Acura TL Ignition Coil Replacement: step 2, image 1 of 2 1999 - 2003 Acura TL Ignition Coil Replacement: step 2, image 2 of 2
    • Pull the hood latch below the steering wheel and near the door frame towards you to pop open the hood.
  3. 1999 - 2003 Acura TL Ignition Coil Replacement: step 3, image 1 of 2 1999 - 2003 Acura TL Ignition Coil Replacement: step 3, image 2 of 2
    • Lift the hood slightly to where your fingers can fit under the hood.
    • Reach your fingers under the hood to find the latch that is slightly right off the center.
    • Pull and hold the latch up while simultaneously lifting the hood all the way up until it stays stationary.
    • Be careful that the hood is lifted properly to avoid an accident.
  4. 1999 - 2003 Acura TL Ignition Coil Replacement: step 4, image 1 of 3 1999 - 2003 Acura TL Ignition Coil Replacement: step 4, image 2 of 3 1999 - 2003 Acura TL Ignition Coil Replacement: step 4, image 3 of 3
    • Use a flathead screwdriver to remove one screw from each corner of the cover.
  5. 1999 - 2003 Acura TL Ignition Coil Replacement: step 5, image 1 of 1
    • Pull the engine cover towards you to remove it.
  6. 1999 - 2003 Acura TL Ignition Coil Replacement: step 6, image 1 of 3 1999 - 2003 Acura TL Ignition Coil Replacement: step 6, image 2 of 3 1999 - 2003 Acura TL Ignition Coil Replacement: step 6, image 3 of 3
    • Pinch the socket, attached to engine coil, and pull up to release.
    • With an Allen key, loosen the screw holding the coil by turning counterclockwise.
    • Make sure to avoid exposed wires.
  7. 1999 - 2003 Acura TL Ignition Coil Replacement: step 7, image 1 of 3 1999 - 2003 Acura TL Ignition Coil Replacement: step 7, image 2 of 3 1999 - 2003 Acura TL Ignition Coil Replacement: step 7, image 3 of 3
    • Pull out the old coil.
    • Avoid exposed wires.
  8. 1999 - 2003 Acura TL Ignition Coil Replacement: step 8, image 1 of 3 1999 - 2003 Acura TL Ignition Coil Replacement: step 8, image 2 of 3 1999 - 2003 Acura TL Ignition Coil Replacement: step 8, image 3 of 3
    • Insert the new coil.
  9. 1999 - 2003 Acura TL Ignition Coil Replacement: step 9, image 1 of 2 1999 - 2003 Acura TL Ignition Coil Replacement: step 9, image 2 of 2
    • Attach the wire socket to the new coil until you hear a "click," indicating that it is properly inserted.
  10. 1999 - 2003 Acura TL Ignition Coil Replacement: step 10, image 1 of 1
    • With an Allen key, tighten the screw into the new coil turning clockwise to secure into place.
  11. 1999 - 2003 Acura TL Ignition Coil Replacement: step 11, image 1 of 3 1999 - 2003 Acura TL Ignition Coil Replacement: step 11, image 2 of 3 1999 - 2003 Acura TL Ignition Coil Replacement: step 11, image 3 of 3
    • Reattach the engine cover and secure the screws with the flathead screwdriver.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 176
