2000 GMC Sierra Lights Replacement
  1. 2000 GMC Sierra Lights Replacement, Headlights, Taillights, and an overhead light: step 1, image 1 of 1
    • Open your tailgate fully, exposing both sides where the tailgate sits.
  2. 2000 GMC Sierra Lights Replacement: step 2, image 1 of 1
    • Unscrew the two phillips head screws located above and below the tailgate support.
  3. 2000 GMC Sierra Lights Replacement: step 3, image 1 of 1
    • Once the screws have been removed, simply pull off the taillight. The red plug is the taillight. Twist it a quarter turn counter clockwise, and pop it out.
  4. 2000 GMC Sierra Lights Replacement: step 4, image 1 of 1
    • Remove the old bulb and replace it with your new one.
    • Side note: Make sure replacement bulb is save voltage/amperage rating.
    • Open the hood and take a look above your headlights.
    • Two metal pins holding each of the headlights in place will need to be removed (no tool necessary).
    • Turn the plastic headlight mount counter clockwise by one quarter of a turn.
    • Then lift the pins up to fully remove them.
    • Once the pins have been removed, GENTLY pull your headlight upwards, towards you. The bulbs should now be exposed. The bulb on the top is your headlight.
    • As you did with the taillight bulb, turn the piece that is holding the bulb in place a quarter turn counter clockwise, and the bulb will pop out. Now your new bulb will take it's place.
5 other people completed this guide.
keith beaudoin
275 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 32
All Time: 802
