2001-2007 Toyota Highlander Engine Air Filter Replacement
  1. 2001-2007 Toyota Highlander Engine Air Filter Replacement, Engine Air Filter: step 1, image 1 of 1
    • Pop the hood open using the latch beneath the driver side dash near the pedals.
  2. 2001-2007 Toyota Highlander Engine Air Filter Replacement: step 2, image 1 of 3 2001-2007 Toyota Highlander Engine Air Filter Replacement: step 2, image 2 of 3 2001-2007 Toyota Highlander Engine Air Filter Replacement: step 2, image 3 of 3
    • Open the hood using the latch beneath the hood.
    • After popping it open, prop it up with the hood stick.
  3. 2001-2007 Toyota Highlander Engine Air Filter Replacement: step 3, image 1 of 1
    • Locate the air filter box in the driver side of the engine bay behind the battery.
  4. 2001-2007 Toyota Highlander Engine Air Filter Replacement: step 4, image 1 of 3 2001-2007 Toyota Highlander Engine Air Filter Replacement: step 4, image 2 of 3 2001-2007 Toyota Highlander Engine Air Filter Replacement: step 4, image 3 of 3
    • Unclip the single clip on the box by pulling up on it.
    • Lift the cover up to remove it from the filter.
  5. 2001-2007 Toyota Highlander Engine Air Filter Replacement: step 5, image 1 of 3 2001-2007 Toyota Highlander Engine Air Filter Replacement: step 5, image 2 of 3 2001-2007 Toyota Highlander Engine Air Filter Replacement: step 5, image 3 of 3
    • Lift the air filter up to remove it from the car and replace it with a new one.
Omar Ajjaoui
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 38
All Time: 1,192
