2002-2009 Chevrolet Trail Blazer Headlight Replacement
  1. 2002-2009 Chevrolet Trail Blazer Headlight Replacement, Headlight: step 1, image 1 of 1
    • Pop your hood with this lever found under your steering wheel.
  2. 2002-2009 Chevrolet Trail Blazer Headlight Replacement: step 2, image 1 of 3 2002-2009 Chevrolet Trail Blazer Headlight Replacement: step 2, image 2 of 3 2002-2009 Chevrolet Trail Blazer Headlight Replacement: step 2, image 3 of 3
    • Use a flathead screwdriver to pop open the clips that hold your front grill on.
  3. 2002-2009 Chevrolet Trail Blazer Headlight Replacement: step 3, image 1 of 3 2002-2009 Chevrolet Trail Blazer Headlight Replacement: step 3, image 2 of 3 2002-2009 Chevrolet Trail Blazer Headlight Replacement: step 3, image 3 of 3
    • Pop off the clips that are holding the headlight in place. Then you will be able to slide the headlight out and have easy access to the bulb.
  4. 2002-2009 Chevrolet Trail Blazer Headlight Replacement: step 4, image 1 of 3 2002-2009 Chevrolet Trail Blazer Headlight Replacement: step 4, image 2 of 3 2002-2009 Chevrolet Trail Blazer Headlight Replacement: step 4, image 3 of 3
    • Turn the bulb halfway to pull it out. Then deattach the wires connected to the old bulb and remove old bulb.
  5. 2002-2009 Chevrolet Trail Blazer Headlight Replacement: step 5, image 1 of 2 2002-2009 Chevrolet Trail Blazer Headlight Replacement: step 5, image 2 of 2
    • Insert your new bulb. Turn half way once it is in to lock it in place. Then attach wires to new bulb. Finally, put the cap over the hold where the bulb goes
2 other people completed this guide.
AARON JOHNSON
169 Reputation
1 Guide authored
One Comment
what about the headlight washers, on the NorthFace Edition
Damien Bellows - Reply
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 114
All Time: 4,253
