2002-2008 Dodge Ram 1500 Differential Oil Replacement
  1. 2002-2008 Dodge Ram 1500 Differential Oil Replacement, Differential Oil: step 1, image 1 of 2 2002-2008 Dodge Ram 1500 Differential Oil Replacement, Differential Oil: step 1, image 2 of 2
    • Locate the twelve 10mm long 14mm hex head bolts holding on the backplate of the differential.
    • Position an oil pan under the differential.
    • Loosen the bottom 4 bolts first with the 14mm socket wrench. Slowly loosen the rest of the bolts in a random order until oil flows out and enters the drain pan.
    • Due to limited resources the oil was not actually replaced in this guide.
  2. 2002-2008 Dodge Ram 1500 Differential Oil Replacement: step 2, image 1 of 1
    • When tightening the bolts on the diff plate it is vital that you tighten them in a star pattern to avoid warping the plate. Do not exceed a torque of 40 ft-lbs per bolt.
    • Repeat the last step in reverse to re-tighten the bolts on the differential cover while following the star method of tightening bolts. Use a torque wrench to ensure proper torque specifications.
    • Now the differential is fully sealed and ready for new oil.
  3. 2002-2008 Dodge Ram 1500 Differential Oil Replacement: step 3, image 1 of 2 2002-2008 Dodge Ram 1500 Differential Oil Replacement: step 3, image 2 of 2
    • Locate the differential filler plug.
    • Use a #2 flathead screwdriver to lift the outer lip of the plug. Pinch the outer lip of the rubber filler plug between your fingers and pull off.
    • Use a vacuum pump to pump in new differential fluid until the oil level reaches the bottom of the plug hole.
    • Re-insert the rubber filler plug.
    • Due to limited resources the differential oil was not changed in this guide.
5 other people completed this guide.
Ken
548 Reputation
2 Guides authored
Cal Poly, Team 3-24, Amido Fall 2012 Member of Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 Members
11 Guides authored
2 Comments
Don’t forget the clean the old gasket material off, wipe up any differential fluid residue, clean the mating surface with brake cleaner, and add a new gasket maker material.
This guide really left out some very important steps. And don’t reuse your diff fluid people.
N S A (Nick) - Reply
No mention of anti-slip additive which is not optional.
Ralph Parker - Reply
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 89
All Time: 36,988
