2002-2008 Dodge Ram 1500 Headlight Assembly Replacement
  1. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement, Headlight Assembly: step 1, image 1 of 3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement, Headlight Assembly: step 1, image 2 of 3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement, Headlight Assembly: step 1, image 3 of 3
    • Open the hood by pulling the hood lever in the driver-side footwell.
    • Reach under the center of the grille and press the hood latch.
  2. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: step 2, image 1 of 1
    • In this guide we will be removing the left headlight. The steps are mirrored for the right headlight.
  3. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: step 3, image 1 of 3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: step 3, image 2 of 3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: step 3, image 3 of 3
    • Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
    • Unscrew the second screw located approximately 6 inches below the first.
    • Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
    • When re-installing the screws do not over tighten. Over tightening the screws will result in stripped threads.
  4. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: step 4, image 1 of 2 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: step 4, image 2 of 2
    • Approach this step with the process of unbuttoning a shirt in mind.
    • Be careful if the rubber gasket is dry-rotted. Use vaseline to re-moisturize if necessary. Manipulating dry-rotted rubber will result in tearing.
    • Pinch the bottom of the rubber gasket at the left side of the assembly and remove it from the plastic "buttons" on the headlight assembly.
  5. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: step 5, image 1 of 2 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: step 5, image 2 of 2
    • Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
    • Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
    • Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
4 other people completed this guide.
Michael Saggese
1,048 Reputation
6 Guides authored
Cal Poly, Team 3-24, Amido Fall 2012 Member of Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 Members
11 Guides authored
9 Comments
Don't forget to explain that there is a third bolt hidden behind the wheel frame under a rubber grommet Other than that hidden bolt. I had both headlights out and replaced in 30 mins.
sreilly623 - Reply
yep. found it. with all humbleness i ask, how do i get it? i am not a car guy. sorry. dont revoke man card.
theycallmemrc -
What wrench size for the bolt in the fender?
Kurt Smith - Reply
10mm for all three of them
Thomas Murray - Reply
I have a question are all 3 bolts the same I lost the one that goes underneath the headlight between the bumper will the other two one or the other still work until I can get replacement
lgweaver80 - Reply
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 122
All Time: 53,131
