2002-2006 Acura Integra Windshield Wipers Replacement
  1. 2002-2006 Acura Integra Windshield Wipers Replacement, Windshield Wiper: step 1, image 1 of 3 2002-2006 Acura Integra Windshield Wipers Replacement, Windshield Wiper: step 1, image 2 of 3 2002-2006 Acura Integra Windshield Wipers Replacement, Windshield Wiper: step 1, image 3 of 3
    • Use the tape measure to measure the length of the wiper blades from top to bottom.
    • This will help you determine the correct size of replacement wipers that you will need.
  2. 2002-2006 Acura Integra Windshield Wipers Replacement: step 2, image 1 of 3 2002-2006 Acura Integra Windshield Wipers Replacement: step 2, image 2 of 3 2002-2006 Acura Integra Windshield Wipers Replacement: step 2, image 3 of 3
    • Lift the windshield wiper off the windshield.
    • Place a towel underneath the wiper to prevent damage to the windshield if the wiper is dropped.
    • Avoid lifting the windshield wiper too far back; doing so can cause damage to what helps the wiper stay against the windshield.
  3. 2002-2006 Acura Integra Windshield Wipers Replacement: step 3, image 1 of 3 2002-2006 Acura Integra Windshield Wipers Replacement: step 3, image 2 of 3 2002-2006 Acura Integra Windshield Wipers Replacement: step 3, image 3 of 3
    • Lift open the clip above the wiper with one hand while holding the wiper arm up with the other.
    • Opening this clip will allow us to slide the wiper off for the next step.
  4. 2002-2006 Acura Integra Windshield Wipers Replacement: step 4, image 1 of 2 2002-2006 Acura Integra Windshield Wipers Replacement: step 4, image 2 of 2
    • Grab the wiper with one hand while holding the wiper arm up with the other.
    • Slide the wiper down.
    • Once unhooked, pull the wiper back and away from the wiper arm to remove the wiper.
  5. 2002-2006 Acura Integra Windshield Wipers Replacement: step 5, image 1 of 2 2002-2006 Acura Integra Windshield Wipers Replacement: step 5, image 2 of 2
    • Place the replacement wiper against the wiper arm with the hooking mechanism facing the hook of the wiper arm.
    • Slide the wiper up, thus putting it into place.
  6. 2002-2006 Acura Integra Windshield Wipers Replacement: step 6, image 1 of 3 2002-2006 Acura Integra Windshield Wipers Replacement: step 6, image 2 of 3 2002-2006 Acura Integra Windshield Wipers Replacement: step 6, image 3 of 3
    • Once the wiper is slid up all the way, grab the top clip of the wiper.
    • Close the clip until a click is heard.
    • Remove the towel and lower the wiper arm down gently.
Follow these instructions for the second windshield wiper.
Brian Gonzalez
154 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 129
