2002-2006 Toyota Camry Key Fob Battery Replacement
  1. 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 2 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 2
    • Purchase a new lithium coin battery. You can find it at your local hardware store.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  2. 2002-2006 Toyota Camry Key Fob Battery Replacement: step 2, image 1 of 1
    • Use your hands or a spudger to separate the key fob into two pieces.
  3. 2002-2006 Toyota Camry Key Fob Battery Replacement: step 3, image 1 of 1
    • Identify which part of the FOB holds the battery.
    • You will not need the other part of the fob until the end.
  4. 2002-2006 Toyota Camry Key Fob Battery Replacement: step 4, image 1 of 2 2002-2006 Toyota Camry Key Fob Battery Replacement: step 4, image 2 of 2
    • Remove the battery from the fob by releasing it from the holder using a spudger or by hand.
    • Be careful that you don't break the contacts when removing the battery.
  5. 2002-2006 Toyota Camry Key Fob Battery Replacement: step 5, image 1 of 1
    • Insert the new battery by pushing it down.
  6. 2002-2006 Toyota Camry Key Fob Battery Replacement: step 6, image 1 of 1
    • Reassemble the fob, using your hands to press the two parts together.
Salman Abu Mazen
140 Reputation
1 Guide authored
UM-Willis-F21S51G7 Member of UM-Willis-F21S51G7
Community
1 Member
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 235
All Time: 5,604
