2003-2007 Honda Accord Key Fob Battery Replacement
Video Overview
  1. 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: step 1, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the screw at the base of the key fob.
  2. 2003-2007 Honda Accord Key Fob Battery Replacement: step 2, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 2, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 2, image 3 of 3
    • Insert a flathead screwdriver into the crack between the top and bottom portions of the key fob.
    • Pry upwards with the flathead screwdriver to loosen the bottom portion of the fob.
    • Remove the bottom portion of the key fob.
  3. 2003-2007 Honda Accord Key Fob Battery Replacement: step 3, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 3, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 3, image 3 of 3
    • Remove the inner portion of the key fob.
  4. 2003-2007 Honda Accord Key Fob Battery Replacement: step 4, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 4, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 4, image 3 of 3
    • Use your fingers to undo the clips at the top and bottom of the fob's inner portion.
    • Separate the two sides of the fob's inner portion.
  5. 2003-2007 Honda Accord Key Fob Battery Replacement: step 5, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 5, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 5, image 3 of 3
    • Use a flathead screwdriver to pry up the circular battery.
    • Remove the key fob's battery.
3 other people completed this guide.
eCuration
378,307 Reputation
236 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,085 Guides authored
One Comment
Very clear and helpful video. Everything worked the way it was shown. Cost was less than $5 for battery, found at Walgreens. Thank you!
Debra Burrell - Reply
Past 24 Hours: 27
Past 7 Days: 266
Past 30 Days: 1,270
All Time: 145,095
