2004-2008 Ford F150 Tail Light Bulb Replacement
  1. 2004-2008 Ford F150 Tail Light Bulb Replacement, Tail Light Bulb: step 1, image 1 of 1
    • Park the vehicle on a level surface.
    • Turn the vehicle off.
    • If the vehicle is not turned off, there is a risk of electrocution upon removal of the tail light.
  2. 2004-2008 Ford F150 Tail Light Bulb Replacement: step 2, image 1 of 1
    • Lower the tailgate.
  3. 2004-2008 Ford F150 Tail Light Bulb Replacement: step 3, image 1 of 3 2004-2008 Ford F150 Tail Light Bulb Replacement: step 3, image 2 of 3 2004-2008 Ford F150 Tail Light Bulb Replacement: step 3, image 3 of 3
    • Use the 8mm socket wrench to remove both of the mounting bolts.
    • An 8mm crescent wrench can be used in place of the 8mm socket wrench.
  4. 2004-2008 Ford F150 Tail Light Bulb Replacement: step 4, image 1 of 2 2004-2008 Ford F150 Tail Light Bulb Replacement: step 4, image 2 of 2
    • Remove the tail light by pulling the tail light housing straight back, away from the vehicle.
    • If the tail light housing is too difficult to remove use a thin, stiff piece of plastic as a pry bar to aid in removing the tail light housing.
    • If a pry bar is used, take caution to not scratch the paint of the vehicle.
  5. 2004-2008 Ford F150 Tail Light Bulb Replacement: step 5, image 1 of 1
    • Twist the upper socket counter clockwise.
    • Pull back to remove the socket from the tail light assembly.
  6. 2004-2008 Ford F150 Tail Light Bulb Replacement: step 6, image 1 of 2 2004-2008 Ford F150 Tail Light Bulb Replacement: step 6, image 2 of 2
    • Pull the bulb out of the socket.
    • When handling the replacement bulb, be careful to minimize contact with the bulb itself; as the oils from your hand can decrease the lifespan of the bulb.
6 other people completed this guide.
Eric Carnes
274 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 80
All Time: 10,558
