2004-2008 Mazda RX-8 Battery Replacement
  1. 2004-2008 Mazda RX-8 Battery Replacement, Battery: step 1, image 1 of 3 2004-2008 Mazda RX-8 Battery Replacement, Battery: step 1, image 2 of 3 2004-2008 Mazda RX-8 Battery Replacement, Battery: step 1, image 3 of 3
    • Find black tabs that lock Battery cover into place.
    • The tabs should snap off easily.
  2. 2004-2008 Mazda RX-8 Battery Replacement: step 2, image 1 of 2 2004-2008 Mazda RX-8 Battery Replacement: step 2, image 2 of 2
    • Use the 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
    • It is vital to disconnect the negative terminal before interacting with the battery. Make sure not to bridge the two terminals with your wrench or other tools.
    • Remove the terminals once nuts are completely loose.
  3. 2004-2008 Mazda RX-8 Battery Replacement: step 3, image 1 of 1
    • Remove Battery terminals.
  4. 2004-2008 Mazda RX-8 Battery Replacement: step 4, image 1 of 1
    • Using the 10mm Wrench remove gold nuts that hold the retention bar in place.
  5. 2004-2008 Mazda RX-8 Battery Replacement: step 5, image 1 of 1
    • After removing the bar pull the dead battery out using the black straps.
After replacing the device, follow these instructions in reverse order to secure a new battery in its place.
2 other people completed this guide.
Gerrit Mouw
253 Reputation
2 Guides authored
Cal Poly, Team 8-4, Regan Spring 2015 Member of Cal Poly, Team 8-4, Regan Spring 2015
CPSU-REGAN-S15S8G4
5 Members
5 Guides authored
One Comment
Thanks!...Ron
sgt.splem - Reply
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 78
All Time: 15,971
