2004-2008 Mazda RX-8 Fuse Replacement
  1. 2004-2008 Mazda RX-8 Fuse Replacement, Fuse: step 1, image 1 of 1
    • Locate the fuse box holder near the driver's side headlight.
    • Remove the cover by lifting the black tabs on the sides.
  2. 2004-2008 Mazda RX-8 Fuse Replacement: step 2, image 1 of 2 2004-2008 Mazda RX-8 Fuse Replacement: step 2, image 2 of 2
    • Remove the cover.
    • There will be a fuse map on the underside of the cover.
  3. 2004-2008 Mazda RX-8 Fuse Replacement: step 3, image 1 of 3 2004-2008 Mazda RX-8 Fuse Replacement: step 3, image 2 of 3 2004-2008 Mazda RX-8 Fuse Replacement: step 3, image 3 of 3
    • Use the tool that is inside the fuse box to remove the necessary fuse.
    • Use the fuse guide on the inside of the fuse cover, along with the nature of the electrical problem to help quickly find the faulty fuse
  4. 2004-2008 Mazda RX-8 Fuse Replacement: step 4, image 1 of 2 2004-2008 Mazda RX-8 Fuse Replacement: step 4, image 2 of 2
    • Replace the bad fuse with a new one.
    • Put the fuse box cover back on and secure the tabs on the side.
Finish Line
Michael Wolfe
118 Reputation
1 Guide authored
Cal Poly, Team 8-4, Regan Spring 2015 Member of Cal Poly, Team 8-4, Regan Spring 2015
CPSU-REGAN-S15S8G4
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 38
All Time: 8,129
