2004 Toyota 4Runner Passenger Side Window Replacement
  1. 2004 Toyota 4Runner Passenger Side Window Replacement, Passenger Side Window: step 1, image 1 of 3 2004 Toyota 4Runner Passenger Side Window Replacement, Passenger Side Window: step 1, image 2 of 3 2004 Toyota 4Runner Passenger Side Window Replacement, Passenger Side Window: step 1, image 3 of 3
    • Before starting, make sure the window is fully rolled down.
    • Prop the door open.
    • Using an upholstery remover, remove the plastic cap.
    • Using a hook tool, remove the plastic panel behind the door handle.
    • Remove the armrest using a trim panel removal tool.
  2. 2004 Toyota 4Runner Passenger Side Window Replacement: step 2, image 1 of 2 2004 Toyota 4Runner Passenger Side Window Replacement: step 2, image 2 of 2
    • Remove the two screws from the door panel using a Phillips #0 screwdriver.
  3. 2004 Toyota 4Runner Passenger Side Window Replacement: step 3, image 1 of 3 2004 Toyota 4Runner Passenger Side Window Replacement: step 3, image 2 of 3 2004 Toyota 4Runner Passenger Side Window Replacement: step 3, image 3 of 3
    • Remove the light using an upholstery remover.
    • Disconnect the lights by applying pressure on the clip and pulling outwards.
  4. 2004 Toyota 4Runner Passenger Side Window Replacement: step 4, image 1 of 3 2004 Toyota 4Runner Passenger Side Window Replacement: step 4, image 2 of 3 2004 Toyota 4Runner Passenger Side Window Replacement: step 4, image 3 of 3
    • Lift the door panel carefully off of the door.
    • Use caution as there are still wires attached to it.
    • Disconnect the green and white wires by pulling outward with your fingers.
    • Disconnect the wires by applying pressure to the sides of the white clip and pulling with your fingers.
  5. 2004 Toyota 4Runner Passenger Side Window Replacement: step 5, image 1 of 2 2004 Toyota 4Runner Passenger Side Window Replacement: step 5, image 2 of 2
    • Remove the four screws using a Phillips #0 screwdriver.
    • Disconnect the speaker by pulling out the white wires.
  6. 2004 Toyota 4Runner Passenger Side Window Replacement: step 6, image 1 of 2 2004 Toyota 4Runner Passenger Side Window Replacement: step 6, image 2 of 2
    • Remove the two bolts using the drive ratchet.
    • The steps are the same for replacing a faulty glass and installing a new glass because the last one shattered. If the previous glass shattered just make sure to clean up all the glass shards in the door with a vaccum.
  7. 2004 Toyota 4Runner Passenger Side Window Replacement: step 7, image 1 of 2 2004 Toyota 4Runner Passenger Side Window Replacement: step 7, image 2 of 2
    • Remove the glass carefully by lifting it up with both hands.
  8. 2004 Toyota 4Runner Passenger Side Window Replacement: step 8, image 1 of 1
    • When installing the new glass, make sure it aligns perfectly in the black molding shown in the picture.
Carlos Lopez
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 34
All Time: 1,319
