2005-2010 Hummer H3 Faulty Speaker Replacement
  1. 2005-2010 Hummer H3 Faulty Speaker Replacement, Disconnect Battery: step 1, image 1 of 2 2005-2010 Hummer H3 Faulty Speaker Replacement, Disconnect Battery: step 1, image 2 of 2
    • Ensure the vehicle is turned off before accessing the battery.
    • Remove the negative terminal first, followed by the positive terminal. Removing the positive terminal first could result in a direct short to the ground.
    • Use your 10-millimeter wrench to remove the hex nuts on the negative terminal. (Image 1)
    • Once the negative terminal's hex nut is removed, we can tuck the negative terminal and cable beside the battery. (Image 2)
    • Repeat these two steps for the positive terminal.
  2. 2005-2010 Hummer H3 Faulty Speaker Replacement, Locate and Remove Plastic Covers: step 2, image 1 of 3 2005-2010 Hummer H3 Faulty Speaker Replacement, Locate and Remove Plastic Covers: step 2, image 2 of 3 2005-2010 Hummer H3 Faulty Speaker Replacement, Locate and Remove Plastic Covers: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Identify plastic covers (Image 1)
    • Remove plastic covers with tweezers (Image 2 & 3)
    • Be careful not to scratch the plastic when you remove the coverings with the tweezers.
  3. 2005-2010 Hummer H3 Faulty Speaker Replacement, Removing the Fasteners: step 3, image 1 of 3 2005-2010 Hummer H3 Faulty Speaker Replacement, Removing the Fasteners: step 3, image 2 of 3 2005-2010 Hummer H3 Faulty Speaker Replacement, Removing the Fasteners: step 3, image 3 of 3
    • Remove the three highlighted fasteners with the T30 Torx Screwdriver. (Image 1 & 2)
    • Use the magnetic pickup tool for loosened stubborn fasteners that are difficult to remove from the socket (Image 3)
  4. 2005-2010 Hummer H3 Faulty Speaker Replacement, Detaching Door Panel: step 4, image 1 of 3 2005-2010 Hummer H3 Faulty Speaker Replacement, Detaching Door Panel: step 4, image 2 of 3 2005-2010 Hummer H3 Faulty Speaker Replacement, Detaching Door Panel: step 4, image 3 of 3
    • The door panel will not fully detach in this step. Do not yank after the panel is released from the frame!
    • It is recommended to have an extra helping hand for the following steps.
    • Shimmy the prybar along the outlined area until you feel a slight detachment from the door panel. (Image 1)
    • Grab the door panel and pull the bottom portion towards yourself slightly. (Image 2)
    • With the panel pulled slightly towards you, you can lift it, releasing it from the frame. (Image 3)
  5. 2005-2010 Hummer H3 Faulty Speaker Replacement, Disconnecting Cables from the Panel: step 5, image 1 of 3 2005-2010 Hummer H3 Faulty Speaker Replacement, Disconnecting Cables from the Panel: step 5, image 2 of 3 2005-2010 Hummer H3 Faulty Speaker Replacement, Disconnecting Cables from the Panel: step 5, image 3 of 3
    • Do not yank the door panel.
    • Having an extra helping hand hold the panel while you complete the following steps is recommended.
    • Locate the two metal cables used for the handle and locking mechanism attached to the ball sockets behind the door panel. (Image 1)
    • Rotate the yellow cable 90 degrees counterclockwise and lift the cable from the ball socket. Repeat for the green cable. (Image 2)
    • With both cables removed from the panel, we can now remove the Blue electrical cable.
    • Press on the clip of the blue cable and gently unplug. (Image 3)
  6. 2005-2010 Hummer H3 Faulty Speaker Replacement, Removing faulty rear side speaker: step 6, image 1 of 3 2005-2010 Hummer H3 Faulty Speaker Replacement, Removing faulty rear side speaker: step 6, image 2 of 3 2005-2010 Hummer H3 Faulty Speaker Replacement, Removing faulty rear side speaker: step 6, image 3 of 3
    • Locate the four fasteners that hold the speaker in place. (Image 1)
    • Use the Phillips Head Screwdriver size PH2 to remove the four fasteners (Image 2)
    • With the fasteners removed, we can gently pull the speaker out, which will reveal the final cable.
    • Locate the clip on the cable connected to the speaker and gently unplug it. (Image 3)
Justin Cobian
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 31
All Time: 237
