2005 Toyota 4Runner V6 Spark Plugs Replacement
Introduction
Go to step 1This guide will provide you with all the necessary steps to properly replace spark plugs in a 2005 Toyota 4Runner V6. Please read each step carefully and heed any warnings found in the guide to prevent running issues. If any running issues occur after the repair, please check the guide for steps with caution symbols as not following these steps correctly can lead to performance issues. Gloves and safety glasses may be worn to prevent injuries , especially if you are new to working with hand tools. One last thing you need to be aware of is that vehicles typically will need an idle relearn after the battery has been disconnected for more than 60 seconds. This doesn’t require any additional steps other than allowing the vehicle to idle (sit and run in your driveway or repair facility) for around 30 minutes after the repair is complete.
Parts
Tools
Show more…
Before getting started, remove the key and pop the hood. To pop the hood, pull on the hood pop handle under the driver's side dash.
To open the hood, find the hood release latch toward the front/center of the vehicle, under the partially popped hood. Once this is released, the hood will pop and you are ready to start working.
Remove the plastic intake breather tube by disconnecting the pressure clamps on the air-filter housing.
Using the Phillips #2 screwdriver to loosen the clamp connecting the air breather tube to the air dam.
Remove the wiring harness clip from the side of the breather tube by pulling up on the plastic clip. Set the breather tube aside.
Put a new spark plug in the spark plug socket
Put the new spark plug in the spark plug tube and use the spark plug socket and extension only to turn the spark plug in a clockwise rotation by hand until the spark plugs feel tight. Repeat for the other five new spark plugs.
Once the spark plugs are partially set, use the ratchet to tighten the spark plugs until they feel sufficiently snug. Once snug, complete one final 1/4 turn with the ratchet to completely seat the new spark plugs.
Reinstall in the reverse order.
