2006-2015 Mercedes Key Fob Battery Replacement
  1. 2006-2015 Mercedes Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 3 2006-2015 Mercedes Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 3 2006-2015 Mercedes Key Fob Battery Replacement, Key Fob Battery: step 1, image 3 of 3
    • The release switch is at the bottom of the key under the unlock button and the trunk button.
    • Slide the release switch to the side.
    • While sliding the release switch, pull the key out.
  2. 2006-2015 Mercedes Key Fob Battery Replacement: step 2, image 1 of 2 2006-2015 Mercedes Key Fob Battery Replacement: step 2, image 2 of 2
    • Insert the key in the inside slit to release the back cover.
    • Remove the back cover.
  3. 2006-2015 Mercedes Key Fob Battery Replacement: step 3, image 1 of 3 2006-2015 Mercedes Key Fob Battery Replacement: step 3, image 2 of 3 2006-2015 Mercedes Key Fob Battery Replacement: step 3, image 3 of 3
    • Insert the pointed end of a spudger in the gap between the battery and the key.
    • Push up after inserting the screwdriver to pry the battery out.
  4. 2006-2015 Mercedes Key Fob Battery Replacement: step 4, image 1 of 2 2006-2015 Mercedes Key Fob Battery Replacement: step 4, image 2 of 2
    • Slide the new battery in at the edge first. (It should fall into place.)
  5. 2006-2015 Mercedes Key Fob Battery Replacement: step 5, image 1 of 2 2006-2015 Mercedes Key Fob Battery Replacement: step 5, image 2 of 2
    • Put the back cover back in place.
    • Put the key in its original spot.
Finish Line
3 other people completed this guide.
Miller Marzouk
193 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 24
Past 7 Days: 184
Past 30 Days: 773
All Time: 12,099
