2006-2013 Toyota Corolla Brake Light Replacement
  1. 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: step 1, image 1 of 3 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: step 1, image 2 of 3 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: step 1, image 3 of 3
    • Open the trunk of the vehicle.
    • Locate the taillight area that needs fixing either on the right and/or left.
    • We are fixing the left side in this guide.
  2. 2006-2013 Toyota Corolla Brake Light Replacement: step 2, image 1 of 1
    • Using a flathead screwdriver, pry the 3 fasteners out.
  3. 2006-2013 Toyota Corolla Brake Light Replacement: step 3, image 1 of 2 2006-2013 Toyota Corolla Brake Light Replacement: step 3, image 2 of 2
    • Pull back the covering to reveal the taillight area.
    • Locate the brake light bulb in the brown socket at the inner end of the taillight area.
  4. 2006-2013 Toyota Corolla Brake Light Replacement: step 4, image 1 of 2 2006-2013 Toyota Corolla Brake Light Replacement: step 4, image 2 of 2
    • Rotate the brown socket counterclockwise and pull out the socket.
    • Pull the nonfunctioning light bulb from its socket and replace with the new, functioning bulb
    • Put the brown socket back in place and rotate clockwise to secure it
    • Put the covering back in place and secure the 3 fasteners. No tools are required, simply push the fasteners into position.
2 other people completed this guide.
2 Comments
I had to use pliers carefully to turn the brown socket, but this worked perfectly. Thank you!
Josh - Reply
Wrong bulb #. Must order Sylvania 3157 for Brake Light .
https://www.partsource.ca/products/3157l...
fruitfly - Reply
Past 24 Hours: 11
Past 7 Days: 71
Past 30 Days: 354
All Time: 9,584
