2006-2011 Cadillac DTS Fuse Box Replacement
  1. 2006-2011 Cadillac DTS Fuse Box Replacement, Fuse Box: step 1, image 1 of 2 2006-2011 Cadillac DTS Fuse Box Replacement, Fuse Box: step 1, image 2 of 2
    • Pull on the seat with your hand to remove the cover.
  2. 2006-2011 Cadillac DTS Fuse Box Replacement: step 2, image 1 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 2, image 2 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 2, image 3 of 3
    • Push down on the button with your fingers, then uncouple the connection between the seat cover and the car.
    • Do not pull on the wires themselves. Grasp each of the two white connectors.
    • Set the seat cover aside.
  3. 2006-2011 Cadillac DTS Fuse Box Replacement: step 3, image 1 of 2 2006-2011 Cadillac DTS Fuse Box Replacement: step 3, image 2 of 2
    • Unscrew the 10 mm hex lug from the positive connection on battery with the 10 mm torque wrench.
  4. 2006-2011 Cadillac DTS Fuse Box Replacement: step 4, image 1 of 2 2006-2011 Cadillac DTS Fuse Box Replacement: step 4, image 2 of 2
    • Pull the wire from the terminal and set the wire aside.
    • Wedge in a flat head screw driver and use it as leverage to pop the wire off the terminal.
  5. 2006-2011 Cadillac DTS Fuse Box Replacement: step 5, image 1 of 2 2006-2011 Cadillac DTS Fuse Box Replacement: step 5, image 2 of 2
    • Unscrew the 11 mm hex lug from the positive wire from the fuse box.
  6. 2006-2011 Cadillac DTS Fuse Box Replacement: step 6, image 1 of 2 2006-2011 Cadillac DTS Fuse Box Replacement: step 6, image 2 of 2
    • Pull the positive connection from the terminal.
    • Place the wire aside.
  7. 2006-2011 Cadillac DTS Fuse Box Replacement: step 7, image 1 of 2 2006-2011 Cadillac DTS Fuse Box Replacement: step 7, image 2 of 2
    • Unscrew the three 100 mm hex lug screws holding down the fuse box to the car using the 10 mm torque wrench.
  8. 2006-2011 Cadillac DTS Fuse Box Replacement: step 8, image 1 of 2 2006-2011 Cadillac DTS Fuse Box Replacement: step 8, image 2 of 2
    • Pull the cover from fuse box.
  9. 2006-2011 Cadillac DTS Fuse Box Replacement: step 9, image 1 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 9, image 2 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 9, image 3 of 3
    • Uncouple the four tabs on both side of the box. Wedge a flat head screw driver in between the gaps and use as leverage to assist in process.
  10. 2006-2011 Cadillac DTS Fuse Box Replacement: step 10, image 1 of 2 2006-2011 Cadillac DTS Fuse Box Replacement: step 10, image 2 of 2
    • Flip the fuse box over.
  11. 2006-2011 Cadillac DTS Fuse Box Replacement: step 11, image 1 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 11, image 2 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 11, image 3 of 3
    • Loosen the three screws holding down the blocks using a 7mm torque wrench.
    • Blocks will raise as you loosen the screw, but screws will NOT come out.
  12. 2006-2011 Cadillac DTS Fuse Box Replacement: step 12, image 1 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 12, image 2 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 12, image 3 of 3
    • Pull the block from the box. Wedge a flat-head screw driver in between the block and use the screwdriver as leverage to pop the block from the box.
  13. 2006-2011 Cadillac DTS Fuse Box Replacement: step 13, image 1 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 13, image 2 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 13, image 3 of 3
    • Push down on the button to uncouple the blue tag from the connection. Use a flat head screw to assist in pushing down the button.
  14. 2006-2011 Cadillac DTS Fuse Box Replacement: step 14, image 1 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 14, image 2 of 3 2006-2011 Cadillac DTS Fuse Box Replacement: step 14, image 3 of 3
    • Push down on tab to uncouple the connection from fuse box. Use a flat head screw to assist in pushing down the button.
  15. 2006-2011 Cadillac DTS Fuse Box Replacement: step 15, image 1 of 2 2006-2011 Cadillac DTS Fuse Box Replacement: step 15, image 2 of 2
    • Remove the fuse box from the car.
  16. 2006-2011 Cadillac DTS Fuse Box Replacement: step 16, image 1 of 1
    • Transfer fuses from the old to new box.
Cuong Tran
253 Reputation
1 Guide authored
One Comment
Thank you, your article was very helpful!
Jim Porter - Reply
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 110
All Time: 1,930
