2006-2011 Honda Civic Dome Light Replacement
  1. 2006-2011 Honda Civic Dome Light Replacement, Dome Light: step 1, image 1 of 2 2006-2011 Honda Civic Dome Light Replacement, Dome Light: step 1, image 2 of 2
    • Before replacing the dome light and to avoid a short circuit, disconnect the car battery first.
    • Open the hood of your car by pressing the front latch and lift the hood.
    • Carefully attach the hood strut, (located towards the left of your car's engine), into the slot to hold the weight of the hood.
    • Disconnect the positive terminal of the battery in order to avoid short circuits.
  2. 2006-2011 Honda Civic Dome Light Replacement: step 2, image 1 of 2 2006-2011 Honda Civic Dome Light Replacement: step 2, image 2 of 2
    • Use a spudger and insert it into the space between the dome light cover and edge.
    • Gently pry the cover off but be careful that you don't break any of the clips attaching the cover to the assembly.
  3. 2006-2011 Honda Civic Dome Light Replacement: step 3, image 1 of 1
    • Evaluate if the bulb is just loose or if it has burned out and needs to be replaced.
    • In this case, you can see that the bulb has turned black from the inside, indicating it has shorted out. This bulb needs to be replaced.
  4. 2006-2011 Honda Civic Dome Light Replacement: step 4, image 1 of 2 2006-2011 Honda Civic Dome Light Replacement: step 4, image 2 of 2
    • Use the spudger to detach the bulb from one end of the socket.
    • Pull the bulb out of the socket with the end that is loose.
  5. 2006-2011 Honda Civic Dome Light Replacement: step 5, image 1 of 1
    • Align the new bulb with the socket and push it back into place.
    • Ensure the bulb is connected to each end of the socket or it will not function.
  6. 2006-2011 Honda Civic Dome Light Replacement: step 6, image 1 of 3 2006-2011 Honda Civic Dome Light Replacement: step 6, image 2 of 3 2006-2011 Honda Civic Dome Light Replacement: step 6, image 3 of 3
    • Before attaching the cover of the dome light, reconnect the car battery carefully and test the light to make sure it works.
    • Align the tabs on the dome light cover with the holes in the assembly and push the cover back into place.
  7. 2006-2011 Honda Civic Dome Light Replacement: step 7, image 1 of 1
    • You should now have a functioning dome light.
Hashim
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 82
All Time: 1,106
