2006 Honda Shadow Spirit 750 Battery Replacement
  1. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove outer casing: step 1, image 1 of 1
    • Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
  2. 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: step 2, image 1 of 3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: step 2, image 2 of 3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: step 2, image 3 of 3
    • The tool box is located under the panel.
    • Using the key to the motorbike, unlock the tool box.
    • Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
  3. 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: step 3, image 1 of 2 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: step 3, image 2 of 2
    • Using the allen wrench, remove the screws on both sides of the bike seat.
  4. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the seat: step 4, image 1 of 1
    • Pull the rear of the seat upwards.
    • Pull the seat backwards to remove it from the bike.
  5. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove plastic covering: step 5, image 1 of 1
    • Using the screwdriver, remove the screw holding the plastic cover.
  6. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the fusebox: step 6, image 1 of 1
    • Pull the cover off the battery and remove the fuse box from the cover.
    • Place the fuse box over to the side right of the bike. Do not disconnect the wires.
  7. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the ground wire: step 7, image 1 of 1
    • Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
    • Place the wire over the left side of the bike.
  8. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the power cable: step 8, image 1 of 1
    • Also using the screwdriver, remove the positive (+) cable from the battery.
    • Place the wire over the right side of the bike.
    • Do not let the red(+) and black(-) wires touch
  9. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the battery: step 9, image 1 of 1
    • Remove the battery from the bike by pulling upwards.
9 other people completed this guide.
Dazarene Cascio
736 Reputation
2 Guides authored
USF Tampa, Team 1-7, Donnelly Fall 2014 Member of USF Tampa, Team 1-7, Donnelly Fall 2014
USFT-DONNELLY-F14S1G7
1 Member
2 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 103
All Time: 19,000
