2006 Iron Horse Warrior Rear Wheel Replacement
  1. 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: step 1, image 1 of 2 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: step 1, image 2 of 2
    • Turn the bike upside down if you don't have a bike stand. This will make it easier to remove the tire.
    • Unfasten the left side of the wheel by pulling the black "L" shaped lever up with your hands.
  2. 2006 Iron Horse Warrior Rear Wheel Replacement: step 2, image 1 of 2 2006 Iron Horse Warrior Rear Wheel Replacement: step 2, image 2 of 2
    • On the right side, use your hands to unscrew the cap of the axle counterclockwise until it is loose.
  3. 2006 Iron Horse Warrior Rear Wheel Replacement: step 3, image 1 of 2 2006 Iron Horse Warrior Rear Wheel Replacement: step 3, image 2 of 2
    • Push down on the the tire with your hands to remove it from the frame of the bike.
    • Sometimes the axle will get caught in the boxed area. Use both of your hands to cautiously push it down harder until the tire comes loose. This may require a fair amount of force.
Matt Halvorson
354 Reputation
2 Guides authored
Cal Poly, Team 15-2, Amido Spring 2015 Member of Cal Poly, Team 15-2, Amido Spring 2015
CPSU-AMIDO-S15S15G2
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,069
