2007 Honda CR-V Brake Light Replacement
  1. 2007 Honda CR-V Brake Light Replacement, Brake Light: step 1, image 1 of 3 2007 Honda CR-V Brake Light Replacement, Brake Light: step 1, image 2 of 3 2007 Honda CR-V Brake Light Replacement, Brake Light: step 1, image 3 of 3
    • Grab the handle in the middle of the trunk.
    • Use the handle to pull the trunk open.
  2. 2007 Honda CR-V Brake Light Replacement: step 2, image 1 of 2 2007 Honda CR-V Brake Light Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the top and bottom screws.
  3. 2007 Honda CR-V Brake Light Replacement: step 3, image 1 of 2 2007 Honda CR-V Brake Light Replacement: step 3, image 2 of 2
    • Pull back the tail light cover.
    • Hold it up; there are cords connected to the car inside.
  4. 2007 Honda CR-V Brake Light Replacement: step 4, image 1 of 3 2007 Honda CR-V Brake Light Replacement: step 4, image 2 of 3 2007 Honda CR-V Brake Light Replacement: step 4, image 3 of 3
    • Untwist the faulty bulb counter-clockwise.
    • Pull the bulb out of the socket.
  5. 2007 Honda CR-V Brake Light Replacement: step 5, image 1 of 2 2007 Honda CR-V Brake Light Replacement: step 5, image 2 of 2
    • Disconnect the bulb from the cord by popping it off.
  6. 2007 Honda CR-V Brake Light Replacement: step 6, image 1 of 2 2007 Honda CR-V Brake Light Replacement: step 6, image 2 of 2
    • Pop in the Sylvania LongLife Mini Bulb 7443LL.
  7. 2007 Honda CR-V Brake Light Replacement: step 7, image 1 of 3 2007 Honda CR-V Brake Light Replacement: step 7, image 2 of 3 2007 Honda CR-V Brake Light Replacement: step 7, image 3 of 3
    • Insert the bulb into the socket.
    • Twist the bulb in clockwise.
  8. 2007 Honda CR-V Brake Light Replacement: step 8, image 1 of 2 2007 Honda CR-V Brake Light Replacement: step 8, image 2 of 2
    • Set the tail light cover back to the default position over the screw holes.
  9. 2007 Honda CR-V Brake Light Replacement: step 9, image 1 of 2 2007 Honda CR-V Brake Light Replacement: step 9, image 2 of 2
    • Use a Phillips #00 screwdriver to screw in the top and bottom screws.
Finish Line
Dillon Laney
169 Reputation
1 Guide authored
One Comment
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 93
All Time: 1,176
