2008-2012 Honda Accord Headlight Bulb Replacement
  1. 2008-2012 Honda Accord Headlight Bulb Replacement, Headlight Bulb: step 1, image 1 of 1
    • (Right Side Headlight)
    • Turn the wheel all the way inward to have enough clearance.
    • Turn the vehicle fully off before proceeding to the next step.
  2. 2008-2012 Honda Accord Headlight Bulb Replacement: step 2, image 1 of 3 2008-2012 Honda Accord Headlight Bulb Replacement: step 2, image 2 of 3 2008-2012 Honda Accord Headlight Bulb Replacement: step 2, image 3 of 3
    • Locate the inner fender's retainer clips.
    • Using a flat-head screwdriver, pry out the retainer clips.
  3. 2008-2012 Honda Accord Headlight Bulb Replacement: step 3, image 1 of 1
    • Pry back the inner fender liner to gain access to the headlight bulb.
    • An object may be needed to keep the fender liner pulled back
  4. 2008-2012 Honda Accord Headlight Bulb Replacement: step 4, image 1 of 3 2008-2012 Honda Accord Headlight Bulb Replacement: step 4, image 2 of 3 2008-2012 Honda Accord Headlight Bulb Replacement: step 4, image 3 of 3
    • Locate the headlight bulb, and turn the item clockwise so that it points towards the engine.
    • For the left bulb, turn the item counter clock-wise
  5. 2008-2012 Honda Accord Headlight Bulb Replacement: step 5, image 1 of 2 2008-2012 Honda Accord Headlight Bulb Replacement: step 5, image 2 of 2
    • Pull out the headlight bulb from its socket.
    • Be careful while pulling the bulb out, you might damage the bulb or its connected cable.
  6. 2008-2012 Honda Accord Headlight Bulb Replacement: step 6, image 1 of 3 2008-2012 Honda Accord Headlight Bulb Replacement: step 6, image 2 of 3 2008-2012 Honda Accord Headlight Bulb Replacement: step 6, image 3 of 3
    • For a more visible view of this step since the space is small and cluttered. -Credit for these 3 pictures: @PrecisionLED
    • To disconnect the bulb, pinch the top of the white block to release it from the bulb
    • When installing a new bulb, be careful while handling the bulb to not smudge or damage the bulb.
Carson Nguyen
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 20
Past 7 Days: 113
Past 30 Days: 440
All Time: 2,827
