2008 Ford F-150 Air Filter
  1. 2008 Ford F-150 Air Filter, 2008 Ford F-150 Air Filter: step 1, image 1 of 2 2008 Ford F-150 Air Filter, 2008 Ford F-150 Air Filter: step 1, image 2 of 2
    • Turn the engine off.
    • Pull the lever to release the hood.
    • Open the hood.
  2. 2008 Ford F-150 Air Filter: step 2, image 1 of 3 2008 Ford F-150 Air Filter: step 2, image 2 of 3 2008 Ford F-150 Air Filter: step 2, image 3 of 3
    • Find the filter housing unit.
    • Pull the leaver to release the clamp.
    • Move the housing unit out of the way to free the filter.
  3. 2008 Ford F-150 Air Filter: step 3, image 1 of 2 2008 Ford F-150 Air Filter: step 3, image 2 of 2
    • Remove the filter by pulling it straight out.
    • If you are replacing the filter completely, skip to step 7 after completing this step.
  4. 2008 Ford F-150 Air Filter: step 4, image 1 of 1
    • Hit the filter with hand, or on the ground, to remove any large particles that are stuck in the filter.
  5. 2008 Ford F-150 Air Filter: step 5, image 1 of 2 2008 Ford F-150 Air Filter: step 5, image 2 of 2
    • Get a hose with running water.
    • Guide the hose inside the filter, pushing out all the smaller particles.
    • This step will take about 15 minutes, go slow.
  6. 2008 Ford F-150 Air Filter: step 6, image 1 of 2 2008 Ford F-150 Air Filter: step 6, image 2 of 2
    • Place the wet filter outside for it to air dry.
    • Placing the filter in direct sunlight will allow the drying to happen quicker.
  7. 2008 Ford F-150 Air Filter: step 7, image 1 of 1
    • When the filter is completely dry, replace the filter in the housing unit.
  8. 2008 Ford F-150 Air Filter: step 8, image 1 of 3 2008 Ford F-150 Air Filter: step 8, image 2 of 3 2008 Ford F-150 Air Filter: step 8, image 3 of 3
    • Resemble the housing unit and close the hood.
To install a new air filter follow steps 1-3 to remove the old filter and steps 7-8 to install the new air filter
Brennan DuBose
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 9
All Time: 331
