2008 Volkswagen Jetta Radio Replacement
  1. 2008 Volkswagen Jetta Radio Replacement, Radio: step 1, image 1 of 1
    • Starting from the back of the top panel, pry open the top panel with a panel tool.
    • Remove the top panel exposing the under.
    • Be careful when removing the layers as they have very delicate clips holding them together.
  2. 2008 Volkswagen Jetta Radio Replacement: step 2, image 1 of 3 2008 Volkswagen Jetta Radio Replacement: step 2, image 2 of 3 2008 Volkswagen Jetta Radio Replacement: step 2, image 3 of 3
    • Use the T20 Torx screwdriver to remove the single screw.
    • After screw is removed, pull out the cover.
  3. 2008 Volkswagen Jetta Radio Replacement: step 3, image 1 of 1
    • Within the third layer, remove two more screws using the T20 Torx Screwdriver.
    • Use the panel tool to unclip the three clips on the back then remove the 3rd panel.
  4. 2008 Volkswagen Jetta Radio Replacement: step 4, image 1 of 3 2008 Volkswagen Jetta Radio Replacement: step 4, image 2 of 3 2008 Volkswagen Jetta Radio Replacement: step 4, image 3 of 3
    • Use the panel tool and slowly loosen up the outer shell by following the crevice outline.
    • Once loosened up remove the upper face layer.
    • When removing this layer there will be a wire connecting the passenger air bag light. Leave that wire alone and carefully place the layer on the dashboard.
  5. 2008 Volkswagen Jetta Radio Replacement: step 5, image 1 of 2 2008 Volkswagen Jetta Radio Replacement: step 5, image 2 of 2
    • Remove the two screws using the T20 Torx Screwdriver.
    • Use the panel tool once again to carefully open up the crevices on the bottom cover. Remove the layer.
  6. 2008 Volkswagen Jetta Radio Replacement: step 6, image 1 of 1
    • Use the T20 Torx remove the four screws placing the radio in place.
    • Once the screws are removed carefully pull out the radio to reveal the wires connected on the back.
  7. 2008 Volkswagen Jetta Radio Replacement: step 7, image 1 of 3 2008 Volkswagen Jetta Radio Replacement: step 7, image 2 of 3 2008 Volkswagen Jetta Radio Replacement: step 7, image 3 of 3
    • There will be two clipped wires on the back of he radio.
    • Push the clips in on the black wires connected to loosen them up and carefully pull out the wire.
    • The second bunch of wires will only require a flip of the lever down on the bottom of the black outer box. Once flipped up remove the whole box to free the radio.
0 Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 100
All Time: 3,344
