2009-2015 Toyota Prius Cabin Air Filter Replacement
  1. 2009-2015 Toyota Prius Cabin Air Filter Replacement, Cabin Air Filter: step 1, image 1 of 2 2009-2015 Toyota Prius Cabin Air Filter Replacement, Cabin Air Filter: step 1, image 2 of 2
    • Press the button to open the glove box.
  2. 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 2, image 1 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 2, image 2 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 2, image 3 of 3
    • Pull hook away from glove box that's located on the right side, near the passenger door.
  3. 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 3, image 1 of 2 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 3, image 2 of 2
    • On the opposite side of the glove box, apply pressure and pull it towards you to unlatch the left side.
  4. 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 4, image 1 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 4, image 2 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 4, image 3 of 3
    • Hold both sides of the glove box.
    • Push the sides in and lift the glove box up while pulling towards you, to remove the glove box from its compartment.
  5. 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 5, image 1 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 5, image 2 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 5, image 3 of 3
    • Push in the tab on the right side of the filter cover while pulling it towards you.
  6. 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 6, image 1 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 6, image 2 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 6, image 3 of 3
    • Remove the old air filter by lifting it up slightly and pulling it towards you.
  7. 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 7, image 1 of 2 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 7, image 2 of 2
    • Insert the new cabin air filter by aligning it with the empty space and sliding in.
    • Make sure the arrow on the cabin air filter is pointing in the up direction.
  8. 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 8, image 1 of 2 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 8, image 2 of 2
    • Insert the left side of the cover back into its slot.
    • Push the right side of the cover back into its clip to secure it.
  9. 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 9, image 1 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 9, image 2 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 9, image 3 of 3
    • Align the hooks on the glove box with the square holes located at the bottom of the dash.
    • Push the glove box back into the compartment until the sides click into place.
  10. 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 10, image 1 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 10, image 2 of 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: step 10, image 3 of 3
    • Reinstall the hook on the right side of the glove box by pushing it back over the grey tabs.
Raphael Bret-Mounet
205 Reputation
1 Guide authored
UC Davis, Team 2-8, Morris Winter 2023 Member of UC Davis, Team 2-8, Morris Winter 2023
UCD-MORRIS-W23S2G8
2 Members
1 Guide authored
0 Comments
Past 24 Hours: 15
Past 7 Days: 65
Past 30 Days: 265
All Time: 1,913
