2009-2014 Ford F-150 Mirror blinker light Replacement
  1. 2009-2014 Ford F-150 Mirror blinker light Replacement, Open Hood: step 1, image 1 of 3 2009-2014 Ford F-150 Mirror blinker light Replacement, Open Hood: step 1, image 2 of 3 2009-2014 Ford F-150 Mirror blinker light Replacement, Open Hood: step 1, image 3 of 3
    • Open Hood: Open the hood using the hood latch inside the driver side of the car.
    • Pull lever to release the hood.
  2. 2009-2014 Ford F-150 Mirror blinker light Replacement, Disconnect Car Battery: step 2, image 1 of 2 2009-2014 Ford F-150 Mirror blinker light Replacement, Disconnect Car Battery: step 2, image 2 of 2
    • Disconnect Battery: Use an adjustable wrench to disconnect the negative power from the battery (Turn clockwise, then lift).
    • 8 mm socket wrench
    • Be careful when disconnecting battery terminals. Make sure to push wires away.
  3. 2009-2014 Ford F-150 Mirror blinker light Replacement, Remove Mirror Glass: step 3, image 1 of 2 2009-2014 Ford F-150 Mirror blinker light Replacement, Remove Mirror Glass: step 3, image 2 of 2
    • Tilt Mirror Forward and Disconnect Mirror: Locate lock tabs behind the mirror. Apply pressure to all three tabs until the mirror unlatches and you can remove it.
  4. 2009-2014 Ford F-150 Mirror blinker light Replacement, Unscrew Backing: step 4, image 1 of 2 2009-2014 Ford F-150 Mirror blinker light Replacement, Unscrew Backing: step 4, image 2 of 2
    • Unscrew Backing: Locate and unscrew 4 Torx T20 bolts holding backing and disconnect it from the mirror.
    • Two Torx T20 bolts.
  5. 2009-2014 Ford F-150 Mirror blinker light Replacement, Pull backing off: step 5, image 1 of 2 2009-2014 Ford F-150 Mirror blinker light Replacement, Pull backing off: step 5, image 2 of 2
    • pull backing off
  6. 2009-2014 Ford F-150 Mirror blinker light Replacement, Disconnect Old Blinker Light: step 6, image 1 of 2 2009-2014 Ford F-150 Mirror blinker light Replacement, Disconnect Old Blinker Light: step 6, image 2 of 2
    • Disconnect Old Mirror Blinking Light: Disconnect the plug from the rear of the blinker light.
  7. 2009-2014 Ford F-150 Mirror blinker light Replacement, Install New Mirror Blinker Light: step 7, image 1 of 3 2009-2014 Ford F-150 Mirror blinker light Replacement, Install New Mirror Blinker Light: step 7, image 2 of 3 2009-2014 Ford F-150 Mirror blinker light Replacement, Install New Mirror Blinker Light: step 7, image 3 of 3
    • Install New Mirror Blinker Light: Slide new light into the mirror and press firmly until you hear a click.
  8. 2009-2014 Ford F-150 Mirror blinker light Replacement, Connecting Wires to New Blinker Light: step 8, image 1 of 2 2009-2014 Ford F-150 Mirror blinker light Replacement, Connecting Wires to New Blinker Light: step 8, image 2 of 2
    • Reconnect Battery: Reconnect the negative power to the battery to restore power to the truck.
    • Test Blinker: Test your blinker to ensure the new setup works and reassemble your mirror.
Ali Bourguiba
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 627
