2010-2014 BMW X6 Tail Light Bulb Replacement
  1. 2010-2014 BMW X6 Tail Light Bulb Replacement, Tail Light Bulb: step 1, image 1 of 1
    • Turn off the car and let the car cool down for 5 minutes.
  2. 2010-2014 BMW X6 Tail Light Bulb Replacement: step 2, image 1 of 2 2010-2014 BMW X6 Tail Light Bulb Replacement: step 2, image 2 of 2
    • Open the trunk using your key in the trunk key slot or by using the button under the CD player.
  3. 2010-2014 BMW X6 Tail Light Bulb Replacement: step 3, image 1 of 3 2010-2014 BMW X6 Tail Light Bulb Replacement: step 3, image 2 of 3 2010-2014 BMW X6 Tail Light Bulb Replacement: step 3, image 3 of 3
    • Remove the small plastic cover along the vertical edge of the trunk entrance by pulling outwards using the handle.
    • Pull outwards till pannel comes off and place down giving access to the inside of the quarter panel.
  4. 2010-2014 BMW X6 Tail Light Bulb Replacement: step 4, image 1 of 3 2010-2014 BMW X6 Tail Light Bulb Replacement: step 4, image 2 of 3 2010-2014 BMW X6 Tail Light Bulb Replacement: step 4, image 3 of 3
    • Grab the light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  5. 2010-2014 BMW X6 Tail Light Bulb Replacement: step 5, image 1 of 1
    • Remove the light bulbs from their sockets by gently pulling them away from the connectors.
  6. 2010-2014 BMW X6 Tail Light Bulb Replacement: step 6, image 1 of 3 2010-2014 BMW X6 Tail Light Bulb Replacement: step 6, image 2 of 3 2010-2014 BMW X6 Tail Light Bulb Replacement: step 6, image 3 of 3
    • Place the new bulb in the original hole.
    • Turn clockwise to secure the bulb in place.
  7. 2010-2014 BMW X6 Tail Light Bulb Replacement: step 7, image 1 of 2 2010-2014 BMW X6 Tail Light Bulb Replacement: step 7, image 2 of 2
    • Place Plastic cover along the bottom of the trunk next to the corresponding hole.
    • Push cover in till it is flush with a vertical wall of the trunk.
  8. 2010-2014 BMW X6 Tail Light Bulb Replacement: step 8, image 1 of 2 2010-2014 BMW X6 Tail Light Bulb Replacement: step 8, image 2 of 2
    • Close trunk and admire your hard work!
Juan M Perez
190 Reputation
1 Guide authored
One Comment
Good job There
Jose Alberto - Reply
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 94
All Time: 2,370
