2010 Chevrolet Camaro Car Battery Replacement
  1. 2010 Chevrolet Camaro Car Battery Replacement, Battery: step 1, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement, Battery: step 1, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement, Battery: step 1, image 3 of 3
    • Open driver side door.
    • Press the trunk button on the inside of the door to unlock the trunk.
  2. 2010 Chevrolet Camaro Car Battery Replacement: step 2, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 2, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 2, image 3 of 3
    • Be careful to secure the lid once it is opened to avoid it closing on you.
    • Lift up the trunk lid.
  3. 2010 Chevrolet Camaro Car Battery Replacement: step 3, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 3, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 3, image 3 of 3
    • Remove the carpet or objects covering the spare tire cover.
  4. 2010 Chevrolet Camaro Car Battery Replacement: step 4, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 4, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 4, image 3 of 3
    • Twist the knob at the bottom of the trunk counterclockwise.
  5. 2010 Chevrolet Camaro Car Battery Replacement: step 5, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 5, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 5, image 3 of 3
    • Remove the knob.
  6. 2010 Chevrolet Camaro Car Battery Replacement: step 6, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 6, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 6, image 3 of 3
    • Lift up the spare tire cover and pull it up to remove it from the trunk.
  7. 2010 Chevrolet Camaro Car Battery Replacement: step 7, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 7, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 7, image 3 of 3
    • Use a 1/2 inch socket wrench to loosen two 13.2 mm bolts.
  8. 2010 Chevrolet Camaro Car Battery Replacement: step 8, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 8, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 8, image 3 of 3
    • Remove both 13.2 mm bolts.
  9. 2010 Chevrolet Camaro Car Battery Replacement: step 9, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 9, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 9, image 3 of 3
    • Remove the plate.
  10. 2010 Chevrolet Camaro Car Battery Replacement: step 10, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 10, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 10, image 3 of 3
    • Use an 2 mm adjustable wrench to remove the 10.1 mm nut on the negative (black) battery terminal.
  11. 2010 Chevrolet Camaro Car Battery Replacement: step 11, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 11, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 11, image 3 of 3
    • Lift up and remove the (black) negative battery terminal.
  12. 2010 Chevrolet Camaro Car Battery Replacement: step 12, image 1 of 2 2010 Chevrolet Camaro Car Battery Replacement: step 12, image 2 of 2
    • Lightly pull on the vent tube located on the right side of the battery to remove it.
  13. 2010 Chevrolet Camaro Car Battery Replacement: step 13, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 13, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 13, image 3 of 3
    • Pinch your fingers on the red cap covering the positive terminal and open the cap.
  14. 2010 Chevrolet Camaro Car Battery Replacement: step 14, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 14, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 14, image 3 of 3
    • Use a 2 mm adjustable wrench to loosen the 10.1 mm bolt connecting to the positive (red) battery terminal.
  15. 2010 Chevrolet Camaro Car Battery Replacement: step 15, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 15, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 15, image 3 of 3
    • Do not touch the positive and negative leads together. Doing so will create a short circuit resulting in the release of high currents and heat.
    • Lift up and disconnect the positive battery terminal.
  16. 2010 Chevrolet Camaro Car Battery Replacement: step 16, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 16, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 16, image 3 of 3
    • Remove the 13.2 mm bolt that is located on the left side of the battery.
  17. 2010 Chevrolet Camaro Car Battery Replacement: step 17, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 17, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 17, image 3 of 3
    • Lift up and remove battery bolt.
  18. 2010 Chevrolet Camaro Car Battery Replacement: step 18, image 1 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 18, image 2 of 3 2010 Chevrolet Camaro Car Battery Replacement: step 18, image 3 of 3
    • The battery is heavy so lift it with care or get help.
    • Grab onto the handles of the car battery.
    • Lift the battery out of the trunk.
Abigail Ganze
277 Reputation
1 Guide authored
UC Davis, Team 2-8, Morris Spring 2023 Member of UC Davis, Team 2-8, Morris Spring 2023
UCD-MORRIS-S23S2G8
2 Members
1 Guide authored
0 Comments
Past 24 Hours: 9
Past 7 Days: 50
Past 30 Days: 161
All Time: 1,101
