Ensure car jack is ready by rotating handle clockwise completely
Locate metal beam under car used for jacking
Position car jack platform under metal beam
Pump car jack handle to raise up car
Raise up car stand 4 notches
Place car stand underneath wheel metal beam
Lower car onto the stands by rotating the jack handle counter-clockwise (very gently)
Repeat steps 1-3 on driver side of car
At this point, both sides should be raised off the ground
Place clean cardboard underneath the car
Locate the oil container underneath the car (this will require crawling under the car and laying on your back
Locate the bolt used to drain the oil
Position the oil drip pan underneath the bolt
Loosen the bolt by turning the 5/16 allen wrench counter-clockwise
Once loose, remove the bolt by hand
Wait ~10 minutes for all the oil to drain out
Clean up the drainage hole with paper towel
Insert the bolt, turning clockwise
Tighten the bolt with the 5/16 allen wrench until the wrench won't turn any further. This is plenty tight.
Position drip pan underneath the plastic cover as shown in picture
Open the hood of the car
Locate the oil filter
Get new oil filter
Install oil filter
Turn the oil filter counter clockwise to install (as appears to the user)
Tighten by hand until both hands can't get it any tighter - This is plenty tight
Wipe up the oil that spilled out when you replaced the filter
Locate the oil cap
Remove the oil cap
Place funnel into oil cavity
Remove oil dipstick
Clean oil dipstick with paper towel
Insert oil dipstick all the way
Remove oil dipstick
Check Oil Level
If oil is too low, add more
Oil is full when the level is just below the bend in the metal of the dipstick
Empty any remaining oil in the filter into the oil drip pan
Turn the oil filter upside down and place into the box of the filter that was just installed into the car
Mark the filter box as "old"
Return the filter to a mechanic shop for recycling
Prepare car jack by turning the handle clockwise all the way
Pump the car jack and position the jack underneath the metal beam
Continue pumping the jack, raising the car off the car stands
Remove the car stand
Lower the individual car side onto the ground by turning the handle of the car jack counter-clockwise
Repeat step 18 and 19 for the other side of the car
Turn on car
Leave car running for 5 minutes to let oil circulate
After 5 minutes, check oil level using the dipstick
If oil level has dropped, add more oil - this is normal,
Place funnel into oil container
Pour the old oil into the recently-emptied oil container
Mark the oil container as "old" and return to a mechanic shop for recycling
Drive off into the sunset
Enjoy a cool beverage (but not while driving off into the sunset)
3 other people completed this guide.
2 Comments
Excellent guide, very well explained.
Just a comment; I have a 2017 VW Jetta, it is a 2.5 with 5 cylinders and it needs more motor oil than stated.
