2011- 2017 Volkswagen Jetta Alternator Replacement
  1. 2011- 2017 Volkswagen Jetta Alternator Replacement, Unlock hood: step 1, image 1 of 1
    • Latch is located below steering wheel.
  2. 2011- 2017 Volkswagen Jetta Alternator Replacement, Open hood: step 2, image 1 of 1
    • Find latch above Volkswagen symbol on grill and open.
  3. 2011- 2017 Volkswagen Jetta Alternator Replacement, Disconnect the negative terminal on the battery: step 3, image 1 of 2 2011- 2017 Volkswagen Jetta Alternator Replacement, Disconnect the negative terminal on the battery: step 3, image 2 of 2
    • Use the 10 mm socket wrench to do this step.
    • Loosen the nut on the connector by turning it counter-clockwise.
  4. 2011- 2017 Volkswagen Jetta Alternator Replacement, Disconnect positive terminal on battery: step 4, image 1 of 1
  5. 2011- 2017 Volkswagen Jetta Alternator Replacement, Clear both terminals: step 5, image 1 of 1
    • Ensure that both terminals are clear before continuing.
  6. 2011- 2017 Volkswagen Jetta Alternator Replacement, Locate alternator: step 6, image 1 of 1
    • The alternator will be on the left side when facing engine​
  7. 2011- 2017 Volkswagen Jetta Alternator Replacement, Locate belt loosening bolt​: step 7, image 1 of 1
    • The belt loosening bolt is on the left, below the alternator.
  8. 2011- 2017 Volkswagen Jetta Alternator Replacement, Loosen bolt: step 8, image 1 of 2 2011- 2017 Volkswagen Jetta Alternator Replacement, Loosen bolt: step 8, image 2 of 2
    • Using 11/16 in. socket, rotate clockwise to loosen the bolt
  9. 2011- 2017 Volkswagen Jetta Alternator Replacement, Remove belt: step 9, image 1 of 1
    • Push the belt off of the alternator.
    • Do not completely remove belt from engine.
  10. 2011- 2017 Volkswagen Jetta Alternator Replacement, Locate screws holding the alternator in place: step 10, image 1 of 2 2011- 2017 Volkswagen Jetta Alternator Replacement, Locate screws holding the alternator in place: step 10, image 2 of 2
    • Locate the 4 screws holding the alternator in place two on the top and two on the bottom.
  11. 2011- 2017 Volkswagen Jetta Alternator Replacement, Remove screws from alternator: step 11, image 1 of 2 2011- 2017 Volkswagen Jetta Alternator Replacement, Remove screws from alternator: step 11, image 2 of 2
    • Using the 1/2 in. socket, remove the screws.
  12. 2011- 2017 Volkswagen Jetta Alternator Replacement, Remove cap and electrical connector: step 12, image 1 of 1
    • Remove cap and electrical connector located on the right side of the alternator before removing the alternator.
    • Photo was taken after the alternator was removed to provide a better picture.
  13. 2011- 2017 Volkswagen Jetta Alternator Replacement, Remove the alternator: step 13, image 1 of 1
    • Take alternator out of engine by pulling to the left and out.
4 other people completed this guide.
Andrew Shutt
337 Reputation
1 Guide authored
2 Comments
What engine is this guide for?
Colin Smith - Reply
Don’t think you can get the alternator out without tying back the coolant hose in the way and probably removing the fans as there is not enough space to get it out otherwise idk how this guide managed to.
begiibole - Reply
Past 24 Hours: 3
Past 7 Days: 62
Past 30 Days: 252
All Time: 11,368
