2011 Ford Focus Air Conditioning Refrigerant Replacement
  1. 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: step 1, image 1 of 3 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: step 1, image 2 of 3 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: step 1, image 3 of 3
    • Turn the car on and the A/C to the maximum.
  2. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: step 2, image 1 of 1
    • Open your car's hood.
  3. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: step 3, image 1 of 2 2011 Ford Focus Air Conditioning  Refrigerant Replacement: step 3, image 2 of 2
    • Locate the low-pressure charging port.
  4. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: step 4, image 1 of 1
    • Remove the cap by turning it counter-clockwise.
  5. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: step 5, image 1 of 2 2011 Ford Focus Air Conditioning  Refrigerant Replacement: step 5, image 2 of 2
    • Connect the nozzle and hold the canister at a 3 o'clock angle.
    • Warning: Keep an eye on the PSI level. It should stay between 30 and 50, as going beyond 50 psi could cause the car's compressor to become damaged.
    • Lock and remove the canister if it is around 40 to prevent it from going to 50 psi.
    • Finally, start up the car. If the air conditioning is cooler, you'll know that it works!
Finish Line
0 Comments
Past 24 Hours: 18
Past 7 Days: 100
Past 30 Days: 529
All Time: 5,260
